Can a built and S/C'd LS1 make 880 rwhp on 93 octane?
Old May 9, 2007 | 07:44 PM
pakisho's Avatar
pakisho is infamous around these parts
Originally Posted by Vicious
no kidding. but not on pump gas.
Im getting tired of repeating myself.
And this is through an Auto. He does have methanol on it, but Methanol is typically worth about 40-50rwhp at that power level, so call it a wash between the auto and the meth.
This link took about ten seconds to find.
Dare I say it again. A 346ci LSX motor can make 800+rwhp on pump gas.
Old May 9, 2007 | 07:51 PM
theprotest's Avatar
theprotest is infamous around these parts
Ah yes, always forget that.
You guys use PON I think, an average of MON & RON. So the equivalent to 98RON is around 95 in your money.
93PON would be roughly 95RON.
Cheers,
Nik
Old May 10, 2007 | 09:17 PM
crazy1323's Avatar
crazy1323 is infamous around these parts
Methanol can actually make a very big difference. Methanol is not only much higher octane the regular 93 gasoline, it also increases power by lowering the temp of the intake charge allowing more timing and more boost.
Basically, methanol injection cools the intake chrage like nitrous while providing some of knock resistence of higher octane fuel.
Old May 10, 2007 | 11:06 PM
pakisho's Avatar
Sure.
But seeing how I run methanol on my own supercharged 346ci LSX motor, and have extensive firsthand experience with it, my statement still stands. Besides, this is only one example.
Old May 11, 2007 | 12:55 AM
crazy1323's Avatar
Then i am sure you have more knowlege about this setup, what is keeping vipers from making much more HP with more displacement?
Old May 11, 2007 | 07:28 PM
pakisho's Avatar
Cant help you there, I dont follow the viper aftermarket closely. Naturally, a larger motor will get to whatever goal you set with less boost, though.
Old May 17, 2007 | 01:51 AM
Zippy's Avatar
With a 3L Whipple & Meth inection?
Old May 19, 2007 | 02:47 PM
Divexxtreme's Avatar
I found out the liar has a 408 stroker and is running meth.
Old May 19, 2007 | 06:20 PM
HotRodGuy's Avatar
eh, cheap upgrade
meth is still pump gas
Old May 19, 2007 | 10:18 PM
blackbenzz's Avatar
blackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of light
You can even use windshield washer fluid
Old May 21, 2007 | 10:44 AM
brent_strong's Avatar
brent_strong is infamous around these parts
Originally Posted by Teck Mafia
No dice on that guy... if that were possible, people would be turning to them instead of 2JZGTE's.
The whole performance world was more or less built on small block chevys. There's no "turning" to them, they're the standard.
Maybe not the end-all be-all of performance, but they're certainly more commonly built than a 2JZ.
Old Jun 26, 2007 | 11:07 AM
02vortec's Avatar
02vortec is infamous around these parts
lots and lots of methanol?
Old Jun 28, 2007 | 12:25 PM
D-VO's Avatar
D-VO is infamous around these partsD-VO is infamous around these parts
You got me there, but this thread delivered and the guy was a liar. I just couldn't see that story being true, so I was right with my no dice comment.
PS see my thread.
Old Jul 4, 2007 | 09:17 AM
Sl33p3rS4's Avatar
Sl33p3rS4 is infamous around these parts
with water or methanol injection it could probably be done.........
it would fight the detonation and allow more boost with lower octane gas
i dont know a lot on the subject but i do know a few people running it in their turbo'd cars and it does the trick
Old Jul 4, 2007 | 12:49 PM
Zippy's Avatar
My 454 Suburban dyno'd 840 RWTQ on 94 gasohol. RWH only came in at 440. This is with a small displacement Whipple, 12 lbs boost and water/Meth injection 60/40.
I think it would be possible to get some big number with the 3.3L whipple, straight meth injection and built heads using 91 octane.
