Clock on '09 AMV8
Old Feb 15, 2010 | 12:38 PM
shvt's Avatar
shvt is infamous around these parts
Clock on '09 AMV8
Before checking with my service advisor at Aston Martin, can someone please check this out for me? At night with the lights on, I noticed that the hour hand on the clock lights up but the minute hand does not. Can someone with an '09 and up check to see if their's is like this as well? I know the clocks on the '07 is different. Thanks in advance.
Old Feb 15, 2010 | 05:57 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
Just checked. The minute hand is lit, but it doesn't show up as bright. If you look close, the hands aren't actually lit, they are clear with sections designed to refract the light that's passing through them. The minute hand only refracts the light at the top of the long end while the hour hand does it at both ends, and is shorter, so it looks a lot brighter.
Unless the minute hand is dirty, it is as it is.
Old Feb 15, 2010 | 11:41 PM
shvt's Avatar
Thanks for checking. I guess the minute hand is thinner so not much light reflects from it.
Old Oct 11, 2016 | 10:07 PM
TorontoDB9's Avatar
TorontoDB9 is infamous around these parts
I see the same thing on my '09 DB9. I thought there was something wrong with the lighting. At night I can barely read the time..... Guess new glasses are in order.
rob4wellness
Oct 2, 2015 07:32 AM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
Compukidd
Sep 30, 2015 11:03 AM
