FYI-Brake Module fault
Old Oct 11, 2016 | 02:04 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
First - I absolutely am a Sportshift person over a manual after learning how it's supposed to be driven. Typically I use it to manually shift through 7th, then let it downshift on its own. I allow plenty of time at start up for the 'kiss' procedure, and with the GT it indicates when that's complete. Over the past several weeks, the downshift and sometimes manually upshift has been a bit odd, occasionally holding too long or abruptly engaging a bit too soon. Then last week I got a engine fault warning that was on for about 30 seconds and went away. Turns out the brake module sent a fault. Also turns out the brake module controls the clutch operation. Under warranty they replaced the module today and now the clutch is as smooth as it should be.
So if you have a sportshift and the clutch becomes weird, check out the brake module.
Old Oct 12, 2016 | 10:59 AM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
thanks for sharing.
Old Oct 12, 2016 | 02:31 PM
got one's Avatar
got one is infamous around these parts
good info, thanks for sharing!
Maybe we should add this to the FAQ?
Mauser
Bentley
38
Jun 13, 2017 03:09 PM
Ruben-Unleashed
Lamborghini
Aug 31, 2016 06:48 PM
circusboy
Aug 13, 2016 07:20 AM
