what's that smell from my 07 vantage?
Old Sep 18, 2010 | 09:41 AM
meteoritesilver's Avatar
meteoritesilver
why is it that when i go real fast and get up to 6,000 rpm's through the gears, i smell a little burning smell? is that normal? 13,500 miles on my AM
THANKS
Old Sep 18, 2010 | 10:05 AM
druid's Avatar
druid is infamous around these parts
I smell that as well when I'm really pushing it (which is pretty much always). I assume it's just the heat smell from the engine. I don't know if there's technically such a thing though. I wouldn't classify it as a clutch smell though.
Old Sep 18, 2010 | 10:37 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
Could be the clutch if you're not shifting smoothly. Why are you only revving to 6000 rpm?
Old Sep 20, 2010 | 03:10 PM
astondude's Avatar
astondude is infamous around these parts
Sounds like the clutch is burning a little....if you do it everytime you drive, you will kill the clutch. It's best not to push over 5500 rpm in 2nd gear. I rev pretty hard too but keep under 5500 rpm. The exhaust bypass valve opens above 4000 rpm...can't get too much louder unless you mod exhaust with super sports.
Old Sep 20, 2010 | 05:49 PM
DrScoles's Avatar
DrScoles has a spectacular aura aboutDrScoles has a spectacular aura aboutDrScoles has a spectacular aura about
Clutch, mine went away. I don't think the previous owner drove my car hard.... I got that smell on the test drive when I was hitting it hard on the freeway. Only does it now if I reverse up a driveway...
Old Sep 20, 2010 | 06:43 PM
Tahoe M3's Avatar
That's not true. The stock clutch is weak, but you can rev to redline (7300 rpm) in any gear. I did it every day when my car was stock, and I still do it every time I drive the car although I have an upgraded clutch.
SlinginHoss
11
Oct 8, 2025 05:16 PM
adnanm3
Oct 25, 2016 08:38 AM
