How to access back of radio for AUX-In install?
Old May 31, 2017 | 07:42 PM
svre46's Avatar
svre46 is infamous around these parts
Originally Posted by Bob in Brighton
Forgot to mention that I also included a Bluetooth dongle so I don't have to have any aux cables running to the interior. Keeps it clean.
Im running an identical setup... I have the MOST AUX wired to constant 12V. When I crank the car the unit goes dead and won't produce any audio or even allow the radio to work until I unplug the most bus and plug it back in. It seems like I need to reset the most bus each time. When I crank it seems like the MOST BUS goes open and nothing syncs. I have the remote wire on a switch like you per the instructions but it seems like the MOST-AUX is the issue since all that wire does is enable the AUX to produce audio. Thoughts?
EDIT:
I think I found my answer. My battery goes to 9.3VDC when cranking causing the issue with the MOST-AUX. Basically it is dropping the loop out. I will update this once I get her charged/and or replaced in case anyone runs into a similar issue.
Old Sep 9, 2019 | 09:40 AM
700OHT's Avatar
700OHT is infamous around these parts
EDIT:
Hi Did you ever get this to work correctly. I have similar issues with the Nav-TV MOST AUX
I really just want to get a decent audio input on the factory system.
MadWhip
Sep 3, 2015 02:04 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
JMon
Aug 21, 2015 08:20 AM
