Options for 2009 Vantage
Old Nov 11, 2010 | 03:12 PM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
I am interested in a 2009 Vantage (want the 4.7) and have not fully sorted out what were the available options, and which were really optional..options.
It seem all Vantages imported into the US for 2009 (and other years) came with: Power folding mirrors, memory mirrors and garage door opener, Cruise Control, Heated front seats, and SATNAV. Maybe others?
Optional Options:
Premium Audio (seem most maybe all have?)
front parking sensors
Sports Package
Optional Wheels
Bluetooth
Battery Charger
umbrella?
Colored calipers
Old Nov 11, 2010 | 06:44 PM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
I'd definitely go with the sports pack. Most cars you will see are pretty well-equipped and should have all of those things including nav and Bluetooth, etc.
Old Nov 11, 2010 | 10:06 PM
scottblack's Avatar
scottblack has a spectacular aura aboutscottblack has a spectacular aura aboutscottblack has a spectacular aura about
MT cars are pretty rare
Old Nov 11, 2010 | 10:31 PM
Allen121's Avatar
Allen121 is infamous around these parts
Best 2009 available is this one.
http://sfbay.craigslist.org/eby/ctd/2054543628.html
Old Nov 12, 2010 | 05:36 AM
millsjq's Avatar
I was trying to see if anyone knew which options all Vantages were imported with and what is the list of "other" options
Old Nov 12, 2010 | 09:01 AM
scottblack's Avatar
Here is the official spec sheet for the car from AMNA:
Specification: 2009 Aston Martin V8 Vantage
Body
Two-door coupe body style or two-door body with soft cover convertible top and heated glass rear screen with 2+0 seating. Bonded aluminum structure, aluminum alloy, steel, composite, and magnesium alloy body. Extruded aluminum side impact bars. Halogen projector headlamps (main beam). LED rear lamps.
Engine
Aston Martin all alloy quad overhead camshaft 32 valve, 4735cc 4.7 liter V8. Variable inlet camshaft timing. Dry sump lubrication system. Fully catalyzed stainless steel exhaust system with active bypass valves. Front-mid mounted engine. Rear wheel drive.
Transmission
Rear mid-mounted six-speed manual gearbox with optional Sportshift*4 automated manual transmission. Alloy torque tube with carbon fiber propeller shaft. Limited slip differential. Final drive ratio 3.909:1
Steering
Rack and pinion, power assisted steering, 3.0 turns lock to lock. Column tilt and reach adjustment. Electronic steering column lock.
Wheels and Tires
Standard: 19’’ alloy wheels – 20 spoke design - Front: 8.5 x 19’’ / Rear: 9.5 x 19’’.
Bridgestone Potenza tires - Front: 235/40 ZR19. Rear: 275/35 ZR19.
Optional: 19’’ alloy wheels – 7 spoke design - Front: 8.5 x 19’’ / Rear: 9.5 x 19’’.
Suspension
Front: Independent double aluminum wishbones incorporating anti-dive geometry, coil springs, anti-roll bar and monotube dampers.
Rear: Independent double aluminum wishbones incorporating anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube dampers.
Brakes
Radial-mounted four-piston monobloc calipers. Dynamic Stability Control (DSC). Traction Control. Anti-lock Braking System (ABS). Electronic Brakeforce Distribution (EBD). Emergency Brake Assist (EBA). Positive Torque Control.
Front: Ventilated grooved steel discs 355mm diameter
Rear: Ventilated and grooved steel discs 330mm diameter
Interior
Full grain leather interior. Alcantara headlining. Alloy facia trim and graphite centre console finish. Electrically adjustable seats. Dual stage driver and passenger airbags. Side airbags. Heated rear screen. Automatic temperature control. Organic Electroluminescent (OEL) displays. Trip computer, Glass ECU. LED map reading lights. Rear parking sensors. Tire pressure monitoring. Alarm and immobilizer. Remote control central door locking and boot release. Battery Disconnect Switch (BDS). Battery conditioner.
In-Car Entertainment
160W Aston Martin Audio System with six-CD autochanger. Integrated Apple iPod® connector*5. USB connector with Waveform Audio Format (WAF), Windows Media Player (WMA) and MPEG (MP3) audio file compatibility.
Options
Sportshift*4 automated manual transmission. Sports Pack. Hard Disk Drive (HDD) satellite navigation system*1+. High Intensity Discharge (HID) Headlamps (dipped beam). Satellite radio system (USA only). Piano Black facia trim. Personalised sill plaques. Auto dimming interior rear view mirror*1. Auto dimming interior rear view mirror with garage door opener*1. Alarm upgrade (volumetric and tilt sensor). Memory seats and exterior mirrors (three positions). Heated seats. Front parking sensors. Tracking device*2. First aid kit. Ashtray and cigar lighter. Cruise control. Bluetooth telephone preparation*1. Powerfold exterior mirrors. Boot mounted umbrella. 700W Aston Martin Premium Audio System with Dolby® Pro Logic II®.
Tomp
Jan 5, 2021 11:59 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
993 Guy
Sep 4, 2015 07:48 PM
