Royal Purple Transmission Fluid Installed ...
Old Dec 26, 2010 | 08:46 AM
klvnwee's Avatar
klvnwee is infamous around these parts
will RP work on a db9 with touchtronic transmission?
Old Dec 31, 2010 | 06:25 PM
Allen121's Avatar
Allen121 is infamous around these parts
Hey guys, I went to the local BMW dealer and bought a quart of Castrol TWS Motorsports 10w-60 oil. Is this the same as their EDGE line? Also, they charged me $20 for the quart.
Old Jan 1, 2011 | 11:28 AM
Allen121's Avatar
Originally Posted by 007 Vantage
That may be their true racing oil. True racing oils are 100% pure synthetics which is why they are so ridiculously expensive. Most over-the-counter "synthetics" are really only a minimum requirement of 30% to be called synthetics. Rarely are they pure synthetics. None the less they still provide far superior protection than pure dino-oil
They said it's what they use for the M3's, which I thought used the same oil as AM dealers just with different packaging.
Old Jan 2, 2011 | 11:28 AM
klittlehale's Avatar
klittlehale is infamous around these parts
I bought the Castrol TWS from my local BMW dealer as well--price was also about $20/qt. It is the OEM motor oil. I bought 6 quarts with the idea that I would probably burn oil when on the track-- keeping the car at high RPM's-- I have probably added one quart in the last year-- the car does not burn or leak oil.
Old Jan 2, 2011 | 07:20 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
007Vantage
Here's an approach to get Castrol TWS 10W-60 for about $145 for 10 quarts includes shipping and no tax.
http://www.velocitymotorcars.com/cas...motor-oil.html
Old Jan 3, 2011 | 05:27 AM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
last time i went to the BMW dealer i got it for about $12 but the price might have gone up. @007 how easy is it to do the transmission fluid change. just like any other vehicle?
Old Jan 3, 2011 | 02:18 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Great thread ... thanks ... moving to RP trans fluid very soon
Old Jan 3, 2011 | 03:53 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Originally Posted by dicktahoe
007Vantage
My recollection is that the owners manual requires Castrol Edge Sport 10W-60 or Castrol Formula RS 10W-60.
Anyone know the difference between Aston's recommended oil and the Castrol TWS link above?
Adam
Old Jan 3, 2011 | 08:07 PM
gsrjc's Avatar
gsrjc is infamous around these parts
You won't regret it ... I promise. The Max-Gear Tranny fluid alone has made me fall in love with my car all over again.
Putting this aftermarket tranny fluid wouldn't void warranty through the ESC is something happened to go wrong with the tranny correct?
Old Jan 4, 2011 | 04:22 PM
alevine's Avatar
UPDATE:
So I decided to put in RP 10w-40 in the engine and ended up doing the oil change yesterday. Glad I did the oil was pretty black and was in need of changing. I will report back in about a weeks time my impressions of the oil and the transmission fluid at the same time.
Thx
007
Just curious, do you think there is risk running 10W-40 as the manual states to use a 10W-60 or 5W-50? The manual specifically states that "No other viscosity grades specifications are acceptable."
See attached. I would like to try another brand but I don't want to jeopardize my warranty.
Adam
File Type: pdf
Old Jan 4, 2011 | 06:05 PM
gsrjc's Avatar
No, there are laws in place to prevent them just blaming the consumer. They would have to do extensive testing to prove that was the cause. And even then they would never know what oil was in there unless you told them.
To me the biggest danger of all is keeping the oem fluid in there since it has to be putting lots of wear on those syncros with all that rough shifting. If anything, tranny life should be extended through wear reduction.
Oh okay... good point about the tranny oil since I guess there isn't anything special about the RP like being a different color so the dealer wouldn't know what type of oil it is.
similar to motor oil... one could use mobil 1 instead of castrol 1 but use the same weight and the dealer wouldn't know.
Old Jan 4, 2011 | 07:17 PM
dicktahoe's Avatar
007 Vantage
I've been following your comments with great interest and plan to change my tranny fluid to RP (How difficult is it to do that myself--Lots of Panels to remove?) Anyway, this is to follow-up on your comment about returning to Castrol 5W-50. I stopped by O'Reillys Auto Parts today (used to be Kragen) and bought a bottle of Castrol Syntec 5W-50 for $7.99+tax. It says on the bottle "Full Synthetic". So I wonder what's the difference between this Castrol and the one BMW sells for nearly 2-times that price?
Old Jan 4, 2011 | 07:27 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Actually, all RP fluids are actually purple but as oil ages it turns a dark color anyway so overtime its much more dificult to tell.
Either way its not anything that should worry you
________
Cheap glass bongs
Old Jan 8, 2011 | 04:03 PM
alevine's Avatar
I went to the parts department of my local BMW dealership. They are selling Castrol TWS Motorsports 10w-60 for $12.50/quart.
I don't recall but did anyone answer your inquiry about how Castrol TWS differs from Castrol Edge Sport?
Thanks,
Adam
Old Jan 11, 2011 | 04:24 PM
I just picked up my 6 Qts of RP Gear Max. Will be scheduling the install soon !
