Royal Purple Transmission Fluid Installed ...
Old Dec 15, 2010 | 08:04 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Royal Purple Transmission Fluid Installed (UPDATED) ...
Review On website:
For the full review visit my website (copy & paste link into browser):
http://www.vantagev8.com/reviews.htm
Old Dec 15, 2010 | 10:20 PM
klittlehale's Avatar
klittlehale is infamous around these parts
Can anyone else comment regarding the "magical" benefits of Royal Purple transmission fluid?
Old Dec 16, 2010 | 10:25 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Thanks for the write up. My only complaint re: shifting my '07 is going from 1st to 2nd when it's cold outside and the car is not warmed up. Does RP help with that issue too? There is an AM mechanical fix to this issue, but, like everything Aston, it is expensive.
Old Dec 16, 2010 | 10:50 AM
Racer_X's Avatar
It does, thanks. Okay, I'm adding RP to the list of items for my dealer to address.
Old Dec 16, 2010 | 01:39 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Cool. Nice write-up and glad to hear it helps.
I wonder if there would be any benefits to replacing the stock fluid in a sportshift with the corresponding RP????
Old Dec 16, 2010 | 03:33 PM
nacelle's Avatar
nacelle is infamous around these parts
Great stuff!
Thanks for sharing!!
Old Dec 18, 2010 | 07:45 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
AM lubricant compromise?
007, our Vantages use the same fluid to lubricate both their rear mounted 6 speeds and differentials. In my experience modern conventionally mounted manual transmissions use thin, waterlike automatic trans fluids and their rear mounted differentials use thicker, higher viscosity lubricants. Perhaps AM compromised, our Vantage components share the same fluid. Do you notice any RP leakage from trans/diff joints, at axle universals or torque tube joint?
Old Dec 18, 2010 | 01:11 PM
flinder's Avatar
007,I gather you use the Royal Purple Max-Gear 75w-90 gear oil in your transaxle. Your RP history is fantastic as is your initial experience in your Vantage. I am looking forward to your long term report as I have the same notchy, difficult to shift when cold issues mentioned above in my Vantage.
Old Dec 19, 2010 | 11:13 AM
CRVETR's Avatar
CRVETR has a spectacular aura aboutCRVETR has a spectacular aura about
What is the motor oil that seems to work best for the Vantage, and what viscosity?
Old Dec 20, 2010 | 02:14 PM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
thanks for your info, ordering
Old Dec 20, 2010 | 02:27 PM
CRVETR's Avatar
thanks, 007
My car will spend all of its time in L.A., so I want to have a motor oil that can handle that climate.
Old Dec 20, 2010 | 07:01 PM
keitheva's Avatar
keitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of light
My local dealer has told me there is an AM service bulletin on the stiff gear-change issue, the fix to which is a realignment of the linkage mechanism or somesuch (at many $$$ cost). They also said a transaxle fluid change alone would not have a significant effect. I know they are in the business of generating business for themselves of course, but are you suggesting the factory recommended fix is in fact unnecessary given your RP experience?
Old Dec 20, 2010 | 07:03 PM
khalid's Avatar
khalid is infamous around these parts
so did any one try the RP tran fluid on a sportshift . is the ss tran oil the same as manual gear ?
Old Dec 21, 2010 | 09:46 AM
keitheva's Avatar
Originally Posted by 007 Vantage
Sounds incorrect to me. Well ... maybe THEIR fluid doesn't do anything, that I would agree with. Having driven on the fluid for about a week now I can honestly say it fixed about 90% of my issues (and the remaining 10% may happen as well too). With that said, surprisingly our gearboxes are cable controlled so there is some level of adjustment, but probably not much.
More likely than not, they just want to do what $tealers do best and charge you more.
Theres only one way to find out, try the fluid and see if you like it. If it still isn't fixed then at least you know for sure its the cables and not just some blind guess.
For under $300 its worth a shot.
Yep, it's worth a shot. Thanks.
Old Dec 24, 2010 | 10:42 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Should be, owners manual only specifies one oil, it does not distinguish between the two. It is the same transmission, and 75w-90 is the most common gear oil for transaxles and diffs.
Just wondering how you settled on RP Max Gear, instead of Mobil 1 Synthetic, RedLine Synthetic or Amsoil Severe Gear--all of which are highly rated 75W-90 Gear Oils?
