02 DB7 No tool kit or spare
Old Feb 21, 2011 | 11:02 AM
DocGaw's Avatar
DocGaw is infamous around these parts
Just purchased a 2002 DB7 Vantage Volante and it is missing the tool kit, and has no spare tire. What's the best approach to replacement or purchasing spare that will fit?
Bill
Old Feb 21, 2011 | 01:04 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
A lot of new Sports cars have no spare. Instead they include an Emergency repair kit in the trunk. Here's one available from Tire Rack that is the same as the kit supplied with newer Astons. You can use it as just a tire pump, or flip up the side case and it will pump in repair fluid and pump up your tire.
http://www.tirerack.com/accessories/...c&AID=10398365&
and here's how it works.
http://www.tirerack.com/accessories/...to_cck_vid.jsp
Old Feb 23, 2011 | 08:06 AM
DocGaw's Avatar
Thank you
Thank you. Have ordered.
Old Mar 15, 2013 | 09:14 PM
allegrobob's Avatar
allegrobob is infamous around these parts
I recently purchased a 2003 db7 and it's missing the trunk platform deck - from photo I understand that it's a hinged plastic panel that covers the battery compartment and other items below the floor. Aston tells me that it's no longer available. Any ideas where I might look or if an early model might fit?
Old Mar 15, 2013 | 09:17 PM
Aerome's Avatar
Aerome is infamous around these parts
Try the breakers
Try to find a breaker in the UK (junkyard here in the US). There are a few advertising on Ebay Motors UK and they're worth an email.
Old Mar 15, 2013 | 11:21 PM
allegrobob's Avatar
Breakers & DB7
Thanks, good thought but I've not been able to locate any used trunk floors in the yards I've checked. I wonder if the trunk shape has changed much...perhaps I could find a newer one.
Old Mar 17, 2013 | 06:32 AM
Aerome's Avatar
I'd say an older one may be better. You can also find a friend and measure on up for fabrication. No brain surgery there. And have you tried to compare what spare tires the XK's were being shipped with?
Jul 29, 2019 11:13 AM
pshep138
Sep 1, 2015 09:45 AM
The Oss
Aug 24, 2015 08:19 PM
oddjob142
Aug 24, 2015 05:49 PM
