squealing brakes--do I have shims?
Old Mar 3, 2011 | 01:30 PM
eelton's Avatar
eelton is infamous around these parts
My new-to-me 2007 V8V is squealing like a banshee. The car spent its previous life in Florida, so it's now seeing cold for the first time, which may be contributing (it's been in the 30s-40s in Chicago).
I know brake squealing a common problem on these cars, and that a service bulletin recommends shims. However, I don't have records showing they've been installed on my car. Looking at the brake pads, though, I think I see shims, but I'm not entirely certain what I'm looking for. Is the thin metal plate on this picture below a shim (see arrows)?
I've tried braking hard, which may have helped a bit. However, given my urban driving, I haven't been able to really speed up and do a panic stop in order to remove the glazing. I'll have to find somewhere to do that this weekend.
Old Mar 3, 2011 | 02:34 PM
orangegrower's Avatar
orangegrower is infamous around these parts
The shim in the service bulletin is a fiber shim that goes on top of the steel shim that you are showing. I have done the service bulletin and changed pads twice but still have some squealing from the rear with light peddle pressure. Good luck.
Old Mar 3, 2011 | 03:39 PM
eelton's Avatar
Thanks. That's helpful.
Old Mar 3, 2011 | 05:18 PM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
Service bulletin attached to help you determine what you have.
File Type: pdf
Old Mar 3, 2011 | 07:36 PM
eelton's Avatar
Great, thanks.
Old Mar 4, 2011 | 06:36 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
I had my pads "fixed by dealer back in 2007 when I first took delivery - no issues after. Then when pads needed to be replaced, went with after market pads that work too ... as in no squeal and minimal dust ... I have StopTech as an example(there are certainly others). I do not have the brake sensors attached ... about the only down side to my pads.
Old Mar 4, 2011 | 07:36 AM
eelton's Avatar
I'll probably go that route as well when the pads need changing, as the brake dust is considerable. Right now, the pads look like they have a lot of life left on them. Having said that, it probably wouldn't cost a whole lot more to have the pads replaced than to have shims installed.
WheelsupZR1
Sep 19, 2015 06:46 AM
xbox_fan
Sep 13, 2015 01:25 AM
oo7
Sep 10, 2015 08:08 AM
