View Poll Results: Do you want aftermarket upgrade E-brake Pads for your V8V?
Yes, great idea
11
78.57%
No, stock is fine
21.43%
Voters: 14. You may not vote on this poll
Aftermarket E-brake brank pad solution ...
Old Apr 19, 2011 | 07:58 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
My main question is: Do you want Carbotech to produce aftermarket E-brake pads for the V8V?
Old Apr 20, 2011 | 07:30 AM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
I do not understand how the emergency brake is adding to the dust/squeak problem unless it is not adjusted properly or the car is driven with the brake on.
Old Apr 20, 2011 | 06:39 PM
millsjq's Avatar
I all for a more cost effective solution. I just was not sure how the emergency brake was contributing to brake dust. Reviewing the shop manual and my understanding of the configuration I really do not think the emergency brake wipes the rotor as a normal operation, sounds like an urban legend
Old May 2, 2011 | 12:46 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Originally Posted by 007 Vantage
UPDATE:
Got the new E-brake pads in ... they are a brembo pad (and appear to be a standard size). I will go ahead and install a brand new stock set of brembo e-brake pads, but I will send off my stock units to see if carbotech can produce a less expensive solution with their 1521 pad compound for the Aston community.
If it can be done, then you will no longer have to pay $147.50 for e-brake pads (ridiculous I know)...
Hope that helps,
007
GOOD ON YA' ! Thanks for going to that trouble so the rest of us can benefit.
Feelgood MD
Mar 24, 2016 09:35 AM
mjdVantage
Sep 5, 2015 07:22 PM
plenum
Sep 2, 2015 09:16 AM
