Vantage V8 you have or have had oil leaks
Old Jan 2, 2018 | 04:30 PM
Miami M3's Avatar
Miami M3 is infamous around these parts
did this problem only affect early 4.3L models? I may go look at a 2011 N420 and need to know what i should be on the lookout for
Old Jan 2, 2018 | 05:27 PM
orangegrower's Avatar
orangegrower is infamous around these parts
Yes, 2007 MY was a problem year and the issue was fixed around that time.
Old Jan 2, 2018 | 09:39 PM
Miami M3's Avatar
thanks!
Old Jan 3, 2018 | 03:09 AM
Aston40's Avatar
Aston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the rough
I had an oil leak at the sump. Ok it took like 5 weeks to drop one drop.
The two pipes that supply/ collect oil from the engine were 'wet"!
And this is how much work it was.
No cover leaks nothing since.
Old Jan 3, 2018 | 06:57 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have a slow leak, but when the car is driven regularly it is too minimal to warrant doing the timing chain cover service. AM dealer did not think it was a big enough deal for me to do the service. I will take their advice when it comes to the maintenance items.
Old Jan 3, 2018 | 07:25 AM
deckman's Avatar
Pretty sure my 13 V8V has a weeping oil leak from the timing cover. Haven't looked closely enough to see the originating location. No drips, just a slight weep. Not enough for me to pay to have it repaired yet. 14k on the odo.
Old Jan 3, 2018 | 09:01 AM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
Is the timing cover fix a diy one? What all goes in with replacing the gasket?
Old Jan 3, 2018 | 04:48 PM
XJRS Owner's Avatar
Ahhh, did you NOT see the photos just above?
Old Jan 4, 2018 | 07:27 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Had an 07 (new) and an 09 (used) - both drove about 20,000 miles zero leaks anywhere, hardly any oil used while driving. Then I bought a 2015 GT - both engine and transaxle had defective gaskets (pinched at assembly!) which would have cost me $9,000 to repair had it not been for warranty!
Old Jan 5, 2018 | 07:48 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Hi...,09 no leaks...but remember the factory modified this year as so many problems with 08 and back vantages...
Evening
Old Jan 6, 2018 | 09:22 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
10', mine had a seep when I bought it with 5700 last year. It was never driven. 10,000 miles later and there isn't even a hint of a seep. Just needed to be driven.
Old Jan 7, 2018 | 07:11 AM
embdenb's Avatar
See http://bernardembden.com/am/timingcover/index.htm
Old Feb 28, 2020 | 02:20 PM
kaj750's Avatar
kaj750 is infamous around these parts
bumping from the dead, because I'm looking to do this.... Can anyone confirm it's 100% impossible to install the new gasket without dropping the suspension/steering rack, etc??
Old Feb 28, 2020 | 04:35 PM
J doubleU's Avatar
You need to drop the front subframe to do it correctly. I don't think its worth trying to sneak a new seal in with the cover half off. That being said nothing is 100% because someone has done a shoddy before.
Old Feb 28, 2020 | 07:50 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
As @J doubleU says, I'm pretty sure I saw a post by @Irish07@VelocityAP a long time ago stating that the engine doesn't have to come out, but it needs to be supported and the sub-frame removed for access. Someone could find it with a search. It's the same procedure posted in the link previously.
