Check engine - need to replace ignition coils
Old Oct 16, 2013 | 01:38 PM
  #46
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
Originally Posted by irish07
So then the DB9 shouldn't take longer than 3.5hrs!!
hope so, maybe you want to come help me,I pay for the drinks
Old Oct 23, 2013 | 03:30 AM
  #47
CARAIBAM's Avatar
Now back from our great Nurburgring week end with a video to prove the quality of my work on the DB7V coils:
Old Nov 1, 2013 | 01:45 PM
  #48
CARAIBAM's Avatar
Should have taken not a lot more,once the manifolds were off I found oil in some of the plug holes,waiting for the cam covers and coils gaskets to arrive.
Old Apr 23, 2014 | 05:12 PM
  #49
RicoDB9's Avatar
RicoDB9 is infamous around these parts
I have an 07 DB9 Sport with 27k on it. I have the typical AM battery issues. In fact it just happened to me last week. Battery went dead and "Emission Service" light went on. It has done it before.
IGNORE IT. Make sure your gas cap seal is clean and cap is tight. Drive it for a few hundred miles and it will go out on its own.
WORSE CASE is go into AM and have them reset the code. If it immediately comes back on you may have an issue but I'll bet you 3 beers it doesn't.
With respect to battery tenders, you can buy a fully electronic 2A smart charger for $40 at Canadian Tire... if your patient they go on sale every once in a while for $25. It has a cigarette lighter adapter and I plug it right into the cigarette lighter interface thing in the trunk... works like a jet!!!
http://www.canadiantire.ca/en/pdp/mo...l#.U1hBFF6_fVk
Old Jan 14, 2016 | 10:48 AM
  #50
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
Didn't want to start a new thread. Going to replace the coils and plugs on my 2009 DB9. Got a quote from nearest dealer for parts -coils, plugs, gaskets for $3300 US.
Sounds high to me. Anyone have sources for parts I can look in to?
Also how about a listing of gaskets I'll need. Anything besides intake?
Thanks.
Old Jan 14, 2016 | 10:59 AM
  #51
RicoDB9's Avatar
Not sure why you would need replace all your coils
I would check with Irish online
AstonMartinBits.com is a good source
Old Jan 14, 2016 | 11:16 AM
  #52
XJRS Owner's Avatar
HWM in the UK. Around $100 per coil, plus intake gaskets, and top and bottom injector o-rings (maybe). Plugs you buy at your nearest auto parts store.
Old Jan 14, 2016 | 04:46 PM
  #53
Old phart's Avatar
So before I buy. 2009 DB9 Volante coils - 3 pin?
Old Jan 16, 2016 | 11:43 AM
  #54
CARAIBAM's Avatar
Yes 3 pins, the 2 pins were fitted to early DB9, circa 2004/2005.Order your parts from Rob SIMS at HWM.
Old Jan 22, 2016 | 08:40 AM
  #55
corveight's Avatar
corveight is infamous around these parts
Do all 2005's have 2-pin? Seems I've read somewhere that no one really knows when they started using 3-pin and the only real way to know was to check the harness or coil to determine which you have.
Old Jan 22, 2016 | 12:39 PM
  #56
CARAIBAM's Avatar
Yes, very unclear, the parts catalog states the two parts but without any Vin n° evolution.
4G4E-12A366-AA Coil assy, ignition-2 pin
4G43-12A366-AA Coil assy, ignition-3 pin
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Fuzzo
Cayenne 955/957
Aug 26, 2015 09:45 AM
oddjob142
Aug 24, 2015 05:49 PM
