front clearance
Old Oct 4, 2011 | 09:10 PM
Norman75's Avatar
Norman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really nice
front clearance
What is the front clearance of the V8V? I'm picking up my car on Thursday it's an 08 V8V roadster and I would like to know if it has higher front clearance than my former 997 turbo. The reason I'm asking is because I have an underground parking in my building where I would love to park the car but I know that the slop was too stip for my Porsche and I scrapped badly the front spoiler when I tried to park it there once. It wasn't a big deal on the Porsche as the spoiler was a cheap piece of plastic that could be easily replaced but it's not the case on the vantage so I don't want to mess it up..
Old Oct 4, 2011 | 09:49 PM
ptaylor_9849's Avatar
ptaylor_9849 is infamous around these parts
Norman, I'll give you some measurements but I'm not sure they will help because there's a lot more to it than just numbers such as angle & pitch etc. The very front nose is raised 5 and three quarters inches. however, there are plastic flaps just forward of the front wheels that are only 3 and three quarters off the ground and finally, the distance from the center of the front wheel to the tip of the nose is appx. 33 inches. Hope this helps.
Old Oct 4, 2011 | 09:56 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
It may not be as bad as you think. There is a "rub-strip" under the spoiler that scrapes when you lose clearance . This plastic strip appears easy to replace after several hundred scrapes. The thing you have to be most aware of is to not hit the front-spoiler on a curb or a "stop-curb" in a parking lot--that would most likely crack it.
Old Oct 4, 2011 | 10:12 PM
Norman75's Avatar
Ha ha indeed that might not help me much since I have no idea what the clearance was on the 997TT
Thanks for the reply though I appreciate
Old Oct 4, 2011 | 10:15 PM
Norman75's Avatar
I didn't notice that plastic strip under the spoiler it's good to know thank you for the info.
Old Oct 5, 2011 | 08:43 AM
CTP855's Avatar
CTP855 is infamous around these parts
Just drive slow, and kind of steer at a right or left angle with the front of your car. I learned immediately with this car, that when I drive onto a parking lot that has a steep entry, I have to slowly angle the front to the left or right. Most of the time this prevents the front from bottoming out. There are many cars on the market that experience this same problem. JUST GO SLOW....AND REMEMBER TO KIND OF ANGLE TO THE RIGHT OR LEFT.
Old Oct 5, 2011 | 09:43 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
I scrape the road from time to time. It's often unavoidable with my car. Agree that as long as you go slow and do what you can to reduce the amount of contact (e.g., approach at an angle), the splitter will be okay.
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
Enemy
Nov 10, 2015 08:01 AM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
