What pressures are you running on 20 alloys?
I have some 20's going on my Vantage 4.3 and was wondering what pressures you guys were running.
Wheels are:
285/30/20 rear
245/35/20 front
They are within 0.8% rolling radius of OEM 19 alloys.
Wheels are:
285/30/20 rear
245/35/20 front
Well first, never change/adjust the tire pressure after a long drive, tires are to hot and this affects tire pressure inside tire, always make sure tire surface is cool to the touch when adjusting pressures, unless you have a gauge to check tire temp and know how to convert temp to pressure adjustment needed..
If temp outside rises, there is no need to change tire pressures to bare with the ambient temp rise in your area. Only place you would adjust pressures due to ambient temp would be on a track where this affects the track temp..on the streets, you don't achieve high enough speeds(for long duration) and high tire temps to worry about tire pressure as a need to reduce track times/ increase top speed/ while improving mpg..
On the streets, it's a K.I.S.S priciple..stick with what is indicated on the Tire Packet label on your door...Vantage front: 33psi, rear: 36psi - DB9/DBS front: 36psi, rear: 38psi
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
COBB Tuning
Sep 9, 2015 09:13 PM
