Thermostat Failed
Old Nov 1, 2011 | 06:27 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
WG_moots
My A-M mechanic indicated that the thermostat has been slightly re-designed so the seal is bigger and fits over more of the valve, so it is less likely to come off. Did you notice any difference between the one you replaced and the new one?
Old Nov 1, 2011 | 09:59 PM
WG_moots's Avatar
WG_moots has a spectacular aura aboutWG_moots has a spectacular aura aboutWG_moots has a spectacular aura about
It was hard to compare the seals as my old one almost looked as if it had been through the shredder.
A new thermostat at the AM dealer is right at $110, I bought the Jag one on-line for $54. The local Jag dealership also wanted $110 for it (they are right across the street from each other, 4 miles down the road from my house).
Even if it isn't the most up to date design, it should hold for a few years ... it is also easy to swap out once you have done it.
Haha, I just read my post above ... it says I bought the thermostat at the Jag dealership. Not sure why I wrote that (getting old I guess). I bought it from Autohaus on-line.
If you aren't entirely comfortable with the Jag part, buy the AM part. It's only $50 difference. The real savings are in doing it yourself.
mxracer
Dec 28, 2015 08:17 AM
Glasgo
Nov 30, 2015 02:37 PM
Im4citadel
Oct 5, 2015 09:04 AM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
