Continued Intake / Vacuum Noise After Engine Shut Down
Old Nov 13, 2011 | 06:02 PM
macksamus's Avatar
macksamus is infamous around these parts
Hi everyone,
So I have another noise question for you all. Prior to taking the car out for a weekend run, I always check the oil level by first running the engine for about 20-30 seconds and then checking the dip stick.
I recently noticed that when I shut the engine down after those first 20-30 seconds, there is a continued intake / vacuum noise that lasts for another 25 seconds or so, despite the engine being shut down.
Here is a video link so you guys can clearly hear what I am talking about.
http://www.youtube.com/watch?v=XRBEFXc2LZU
I should point out that after my drives (i.e., once the engine is warm), there is no continued intake / vacuum noise. This only happens when the engine is cold.
I should also point out that my local AM dealer recently performed the 3-year service on my car, in which the air filters were replaced. Could it be that something was not put back properly?
Thanks in advance for your input.
Eric
Old Nov 14, 2011 | 06:03 AM
Irish07@VelocityAP's Avatar
Haven't listened to the video, but what you described is called secondary air injection..it's normal. There are pumps under the upper intake manifold(in the valley) that perform this duty..if the drive cycle for the secondary air starts, it will continue a few seconds after shut down..again..normal(this operation only works when engine is cold to achieve better/pass-able exhaust emissions)..if there was a fault with this system, being emissions related a MIL would activate.
Old Nov 14, 2011 | 12:08 PM
macksamus's Avatar
Thanks Irish07. That appears to be exactly what it is...also as confirmed by a fellow AM tech.
Jul 29, 2019 11:13 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
mlife2878
Aug 26, 2015 07:02 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
