Car is back, running fine - but....
Old Dec 28, 2011 | 08:17 AM
scottblack's Avatar
scottblack has a spectacular aura aboutscottblack has a spectacular aura aboutscottblack has a spectacular aura about
Originally Posted by Racer_X
These screws are notorious for coming loose and enabling the vent covers to vibrate in place. And the screws are difficult to tighten, even with a flexible or angled screwdriver. I had to get my girlfriend to operate the screwdriver (small hands) while I coached her as to the location of the screw heads while standing outside of the car. The outside screw on each vent is not too hard to access, but the inside screw on each is really hard to reach and even harder to turn.
When I took my '07 Vantage in for service, I requested that they remove each of the four screws and replace them with some Locktite on the threads (the non-permanent variety). Never got to see if this worked, however, because I left the dealership with my V12V.
I assume you have not experienced this issue with the V12V, right? Just curious as to whether or not I will see it crop up again.
Old Dec 28, 2011 | 08:32 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Not yet, but I only have about 3500 miles on the clock. As I recall with the V8V, the screws would need tightening a couple of times a year. I note also though that the V8V rode a lot harder over bumps than the V12V does. Maybe the V12V's screws loosen more slowly as a result. Or, since Aston has known about this issue for years, maybe they finally resolved it.
Old Dec 29, 2011 | 07:08 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
A bigger screw
My's dealer's mechanic, anticipating this rattle/buzz issue, offered 4 next larger diameter screws to replace the OE versions. I changed them during replacement of my cracked windshield. Glass people were wowed by our "anticipation"...they loved the car. Mechanic has become a good friend.
Old Dec 29, 2011 | 07:31 AM
Racer_X's Avatar
I assume that the bigger screws have worked? How many miles have you put on the car since replacing the screws?
Old Dec 29, 2011 | 08:34 AM
Irish07@VelocityAP's Avatar
I don't see to many problems with the vents in my location, usually only on vehicles that are bought from down south, usually from florida/texas area's..have not yet done this repair on a canadian driven vehicle..wondering if it's a hot sun temp issue..
But I don't have to much trouble getting at the screws, mirror and light on the outside flush against the windscreen to see(held in place by wiper blade).. magnetic bit for screws that I shaved down and snake flex extension on my 1/4 electric driver, then 1/4 rachet to torque screws ..works pretty good
Old Dec 29, 2011 | 09:09 AM
flinder's Avatar
Outsmarting the Devil
Bigger screws are in about 7500 miles. Total miles on my 07 coupe, 14,500. Never experienced the problem before or since, although the mechanic, Kyle, had seen the buzz on a high mileage 07 coupe owned by a friend, Pat.
Pat has over 50,000 miles now, including back and forths, Det to Arizona. Heat may aggrivate the issue. Pat's buzz has not returned.
Want insurance, put a daub of urethane, Locktite, epoxy, whatever, on screwtips as you insert them. Doesn't take much, remember, "vibration is the Devil's wrench".
Old Dec 29, 2011 | 09:16 AM
Just be careful using locktite, think it's blue and red and green that will eat plastic..forget what color is suggested, but there is one approved for contact with plastics 100% ..that way if some get on the vent, no damage will ocur
Old Jan 27, 2012 | 11:57 AM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
I went to tighten mine today, and one of the screws appears stripped. Not the head of the screw, but the socket--the screw just spins in the hole. Any suggestions?
Old Jan 27, 2012 | 03:18 PM
flinder's Avatar
The screws require very little torque to perform this task. They pass through the plastic vent bezel and reach down into a steel J clip fastener. J clips are used for many automotive attachment jobs because they are so forgiving especially in "blind" applications like this one. Remove the OE screw and try a similar length but slightly larger barrel diameter screw with the same countersunk head design. Apply a daub of glue, any kind, to the tip as you insert it. Do not distort the bezel by overtightening.
Tight, miserable to work in spaces like this are one of the penalties of our laid back (fast) windshield angle. I sat in the touring 1-77, its w/s is significantly faster.
Old Jan 28, 2012 | 09:08 AM
brumma's Avatar
Thanks!
Old Jan 28, 2012 | 09:15 AM
lhanddds's Avatar
lhanddds is infamous around these parts
That was an expensive fix
Old Jan 28, 2012 | 12:14 PM
Racer_X's Avatar
Yeah, tell me about it! No regrets though.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
Fabspeed Motorsport
NY Tri State
Aug 18, 2015 03:22 PM
