How to remove door panel on Vantage
Old Jan 30, 2012 | 07:05 PM
mark higinbotha's Avatar
mark higinbotha is infamous around these parts
In looking for the rattle inside my drivers door I have been able to get everything loose and off the door panel with the exception of the cable from the inside door release handle to the lock on the end of the door. Any tips?
Thanks!
Old Jan 31, 2012 | 09:41 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There are two clips on either end of the cable end. You have to open them up and then slide cable up out of groove.
Old Jan 31, 2012 | 10:01 AM
AMFixer, Thanks much! I will give that a try.
Old Jan 31, 2012 | 10:02 AM
AMFixer's Avatar
I added a picture too.....
Old Jan 31, 2012 | 11:33 PM
I stopped by my local shop today and the tech just happened to have a door apart and showed me what I was doing wrong. I didn't pull hard enough on the metal door handle to separate it from the soft door panel. No wonder I couldn't see where you and irish07 were telling me how to disconnect the cable.
Thanks very much!
Money2536
Jan 19, 2022 08:22 AM
97GtsMonster
Nov 17, 2015 12:38 PM
henryr
Sep 24, 2015 08:22 PM
away
Sep 4, 2015 12:30 PM
shinjuku
Aug 29, 2015 09:59 PM
