Check tire engine light...help!
Old Feb 27, 2012 | 09:52 AM
rynacd's Avatar
rynacd is infamous around these parts
i rebalanced my wheels and the check tire engine light keeps going on and off. Will stay on for awhile and then after 40 miles turn off. Keeps coming back on.
I know the tire module was remounted inside the tire from the factory wheels to the aftermarket wheels, but balancing shouldn't change anything. Nothing was dismounted. No problems until i got the wheels rebalanced couple weeks ago.
Any suggestions?
Old Feb 27, 2012 | 10:28 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
did u check the tire pressure, the check tire light means a tire is low on air. But "the check tire engine light keeps going on and off", well which is it the tire light or the engine light?
Old Feb 27, 2012 | 10:33 AM
rynacd's Avatar
i believe its the "check tire" light. i checked air pressure and they are set correctly.
Old Feb 27, 2012 | 10:42 AM
AMFixer's Avatar
can u see which light on the module is flashing red? that is your problem tire, now the I only hope they tranfered the color rings to the new rims, cause its a guessing game after that. They either need to be reprogrammed or replaced, I have seen the battery go out in them, 5yr life on the batteries
Old Feb 27, 2012 | 10:49 AM
CJPatel's Avatar
CJPatel has a spectacular aura aboutCJPatel has a spectacular aura about
https://www.6speedonline.com/forums/...html#post32191
Post #8 has a good PDF to guide you through all your TPMS needs. GL
Old Feb 27, 2012 | 10:53 AM
rynacd's Avatar
i thought the module is mounted inside the tire on the wheel? i don't see any flashing lights. thanks for the info
Old Feb 27, 2012 | 10:59 AM
AMFixer's Avatar
the sensor is in the wheel, the module itself is under the glove box area
Old Feb 27, 2012 | 11:02 AM
rynacd's Avatar
i'll check out the thread...thanks u guys.
Old Feb 27, 2012 | 11:27 AM
AMFixer's Avatar
CJPatel your link doesnt work. But I did found the thread, here is the .pdf file CJPatel was giving you.
File Type: pdf
Old Feb 27, 2012 | 11:29 AM
CJPatel's Avatar
Originally Posted by AMFixer
CJPatel your link doesnt work. But I did find the thread, here is the .pdf file CJPatel was giving you.
Thats it! Sorry I dunno what happened with my link. I tried attaching that PDF but couldn't figure that out either.
Old Feb 27, 2012 | 11:31 AM
AMFixer's Avatar
No worries, I found it, and post the pdf. Nice find.
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
L.A.P.
Aug 23, 2015 11:48 PM
