TPMS Resync...
Old May 19, 2011 | 08:08 AM
111R's Avatar
111R is infamous around these parts
TPMS Resync...
...after changing the units. I.e.
-wheel to wheel
-replacing them
Did a forum search (and RTFM) to no avail and wanted to check before I get into things. Is it something as simple as just transferring them from wheel to wheel while keeping the color keyed units together? Does the system require a 'reset' or 're-sync' when this is done? How about if a unit is replaced?
Cheers,
Bobby
Old May 19, 2011 | 09:16 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I need to know this as well
Old May 19, 2011 | 09:24 AM
111R's Avatar
Also, I think I have found an aftermarket option that costs about 1/3-1/4 of the stock ones. My sensors are ok and will transfer to the new wheels. But knowing the above answer might give us an alternative to 1k/set for TPMS. Specially considering that the 06s are nearing the end of their battery life.
Old May 19, 2011 | 10:22 AM
Curtis's Avatar
Curtis is infamous around these parts
I've moved the factory TPMS from the OEM wheels to aftermarket wheels and then back to OEM keeping the color coded stems in the same position on the car and never had one fault. I didn't touch the control unit or reset a thing. Hope that helps.
Old May 19, 2011 | 11:04 AM
Perfect, thats what I thought ... I will just do one at a time.
Old May 19, 2011 | 11:21 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
The system automatically resets itself...by that I mean that when you swap out wheel just keep the stock sensors in the right position and it will adapt. I didn't have any problems when I switched wheels.
Old May 30, 2011 | 05:39 AM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
what is the aftermarket option you might have found?
Old May 30, 2011 | 08:36 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Here is a description of how it works. Some might find useful.
File Type: pdf
Old May 30, 2011 | 10:19 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
OK, so If I replace a faulty sensor, how do I re-sync to the TPMS Unit (the command module)?
Old May 30, 2011 | 11:50 AM
111R's Avatar
I had a person tell me that they had done wheel swaps on AMs with aftermarket sensors. Used his hardware, some AMs were easy to sync some had to go through a few programing runs of the TPMS units.
Old May 31, 2011 | 10:32 PM
zambono's Avatar
i think i found the manufacturers of our TPMS
http://www.bartecusa.com/oem_tpms_to...ufacturers.htm
Old May 31, 2011 | 10:41 PM
zambono's Avatar
correction it might be smartire sensors.
can someone confirm if these sensors are on the valve stems, or wrapped around the rim
Old May 31, 2011 | 10:53 PM
zambono's Avatar
i think i really did find it now, but no details
http://www.hwmastonmartin.co.uk/part...rtsectionID=72
Old May 31, 2011 | 11:18 PM
bigken620's Avatar
bigken620 is infamous around these parts
I have aftermarket wheels that have a deep lip and thus my TPMS sensors had to be wrapped around the rim rather than connected to the valve stem. I haven't had any problems w/ this set up.
Old Jun 1, 2011 | 08:46 AM
111R's Avatar
On the Valvestem curved to fit the rim.
This is an important thread IMO. This is probably one of those oddball consumable items that cars are coming up on needing. I don't mind paying to have them replaced but at 1K/set? That's a bit absurd. I have found aftermarkets that are supposed to fit at around 400/set.
