Steering wheel noises
Old Jan 23, 2013 | 02:44 PM
Malibu101481's Avatar
Malibu101481 is infamous around these parts
Might also just be the leather slightly sliding around on the steering wheel itself
Old Jan 28, 2013 | 01:45 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
how does one flush the system im just curious?
Old Feb 4, 2014 | 12:36 AM
Jeremyosj's Avatar
Jeremyosj is infamous around these parts
Originally Posted by irish07
Grommet can be access from inside and from undernieth..I spray the dry silicone from both sides
Did that work?
My 07 V8V steering makes a noise on the inside of the cabin when I turn the wheel. Sounds like leather to leather rubbing to me.
Old Aug 4, 2022 | 05:26 AM
Aston powers's Avatar
Aston powers is infamous around these parts
Originally Posted by Jarod
I have the same problem on my 2007 V8V. Had it at the dealer, he checked the fluid the mechanical stuff as well as the motor and found nothing. Still have the noise though...
V8V annoying steering sqeak.
I have the same. It’s not the fluid the sound Definately coming from directly behind the steering wheel. Like rubber on rubber. I’ve silicone sprayed the joints on the column and down behind the steering wheel. Drives me mad. Getting a tech to check it.
Old Aug 4, 2022 | 07:09 AM
MRCW's Avatar
I have the same annoying sound. I'm going to try the firewall grommet... let us know what you find.
For me It's only at low speed maneuvering like getting into a parking space or the garage
Old Aug 4, 2022 | 07:29 AM
thats it. At first nothing then after about 5 mins drive it starts. Manoeuvring. Short or long terms of the wheel . I’ve had my head underneath listening nothing on the column. Most odd. Good luck let me know how you get on
Old Aug 4, 2022 | 09:56 AM
wheres this firewall grommet. I thought they were used for running cable through.
Old Sep 20, 2022 | 01:35 PM
peerware's Avatar
peerware is infamous around these parts
Did you ever figured it out? I have the same issue now and its clearly somewhere at the end of the steering wheel.
Old Sep 21, 2022 | 08:23 AM
MRCW's Avatar
So far my solution has been to turn up the music... the sound disappears...
Hopefully this fall when it gets cooler I'll poke around under the dash
Old Sep 24, 2022 | 05:41 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Don't forget the Lubrizol...
Old Oct 3, 2022 | 03:27 AM
Any hi. Any update on this bloody annoying noise. I’ve had techs lubricate everything in sight. Fluid is good. But still squeak bloody squeak. Cheers
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
no1joey
Sep 2, 2015 12:32 AM
Zero911
Aug 24, 2015 06:51 PM
