Car stalls when tank is mid to full ???
Old Mar 25, 2012 | 09:40 AM
lase's Avatar
lase is infamous around these parts
I have noticed when filling up the tank, the car almost immediately starts to fail. Make a u-turn, it shuts off; make any turn fast, the car shuts off...? However, when the tank goes below half, you can track the car and nothing will happen...! Does this mean that I have a problem with the fuel tank, fuel pump, etc.? I have read other people having the same problem but, no solution was stated.
Old Mar 25, 2012 | 12:33 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
My best guess is the purge line in the tank has come loose. The problem you described are what happens when it goes bad. You need to access the fuel tank. Hope you have a drop top, cause hard top cars are a pain to do.
Old Mar 25, 2012 | 06:17 PM
Swoody's Avatar
Swoody is just really niceSwoody is just really niceSwoody is just really niceSwoody is just really niceSwoody is just really nice
So what kind of car and what year are we talking about here?? Also is it failing at the pump while filling...ie...is it running at the pump and stalls when you get beyond half full????
Old Mar 25, 2012 | 07:41 PM
Irish07@VelocityAP's Avatar
Second that, theres a small rubber hose in the tank that comes loose or actually at times just falls apart..small hose needs to be replaced which is for the purge..
Old Mar 26, 2012 | 11:06 AM
ewu64's Avatar
ewu64 is infamous around these parts
I have a hard top...! Does anybody knows how much that costs at the dealer. The two Aston dealers in my area charge whatever they want. I've been quoted for a 4 wheel alignment from $250 to $600...??
Old Mar 26, 2012 | 11:20 AM
AMFixer's Avatar
That sucks.....if your dealer quotes you right I would guess anywhere from 10-15 hours for this. The part is only like $30 bucks, and the added cost for fluids. The repair manual on a coupe requires you to remove the fuel tank to access it. Which requires the tranmission to come out, and the rear subframe, hence so much labor.
Old Mar 26, 2012 | 11:22 AM
telum01's Avatar
Wow...
Old Mar 26, 2012 | 01:25 PM
cshsia's Avatar
cshsia is infamous around these parts
Stuff like this seriously scares me.
Old Mar 26, 2012 | 01:37 PM
AMFixer's Avatar
You know what..... I didn't even notice what kind of car it was. V8's are easy, it's db9's that require all that. This can be easily DIY. The fuel tank is easy to access on v8's
Old Mar 27, 2012 | 08:46 AM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
I sense a strange disturbance in the force as if all the 6Speed V8 owners collectively heaved an enormous sigh of relief while all the V12 coupe owners suddenly cried out in fear and horror.
Old Mar 27, 2012 | 08:56 AM
Benjamin09's Avatar
Benjamin09 is infamous around these parts
Great. Something to give me nightmares now....
10-15 hours of labor.....
Old Mar 27, 2012 | 09:54 AM
WG_moots's Avatar
WG_moots has a spectacular aura aboutWG_moots has a spectacular aura aboutWG_moots has a spectacular aura about
haha, i thought the same thing! big SIGH
AMFixer said it was the DB9 that would be a pain but no the V8V .... wonder where the V12V sits?
Old Mar 27, 2012 | 10:27 AM
AMFixer's Avatar
The V12V would be the same as a V8, but have not seen that issue with them yet.
Old Mar 27, 2012 | 11:41 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
If the V8V is pretty easy to get to, can you see this purge hose without removing the tank? The reason I'm asking is my '08 V8V is about to go out of warrantee, and I'd like to get this hose checked--If it's easy?
Old Mar 27, 2012 | 12:23 PM
AMFixer's Avatar
The Db9 Coupe is the only car that the fuel tank is removed to access. All other have access ports to make it easier to get too.
I posted a walkthough, then I took it down. All I need is someone blowing themselfs up.
I would charge a hour to check, both coupe and volante's.
