Squeak from rear wheel?
Does it go away when you pull slightly up on the parking brake? (keep the button pressed, don't engage the lever and test this in a safe low speed area)
Not sure, will test it ? What are my options, if it does ,or if it does not ?
Well first, process of elimination.. If the noise goes away, it's parking brake related
I tested it and the results were a bit inconclusive. There were times that the noise completly stopped and there were times that it partially went away. What do you think ?
I'd pull the parking brake pads out of the suspected wheel and see if there is a small piece missing of the material from the leading edge...this is common for rocks to chip the pad and force a squeak issue from the parking brake pads.
Jag S Type pads
PenguiN
Nov 12, 2015 05:24 PM
COBB Tuning
Nov 9, 2015 08:02 PM
Sep 1, 2015 03:16 PM
