V8V Premium Audio, rear speakers cut out on FM?
Old 04-24-2012, 10:19 PM
jwbeard's Avatar
jwbeard is on a distinguished road
Hello 6speed,
I have a 2007 V8V with the premium audio system and voice-activated Bluetooth. When I'm listening to FM radio with Dolby PLII enabled, I notice that the rear speakers fade/cut in and out quite a bit, much to my irritation. There's no problem with the fronts, which leads me to rule out a Bluetooth issue.
I verified that this doesn't happen with the CD changer - audio sounds great! Only on FM, and only with the car in motion. If I come to a stop, a "current state" of sound (full, partial rear, no rear) is preserved until I go in motion. I feel like if the FM radio is not receiving a perfect signal, then the Dolby PLII processor has no idea what to do with it and drops/fades the rear channel. I've never had a car that drops audio channels with decreasing radio signal strength, only an increase/decrease in static.
Does anyone else experience this, or could this be an amp/head unit issue? I'm in the SF Bay Area, if anyone else is seeing the same thing.
Thanks!
Old 04-25-2012, 07:07 AM
XJRS Owner's Avatar
XJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond reputeXJRS Owner has a reputation beyond repute
I thought the surround sound doesn't work with over the air sources, only CD, etc? Look in your manual.
Old 04-25-2012, 07:40 AM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
Why would this lead you to rule out Bluetooth as the source of the problem? I agree that it is probably not the issue, but not because of this--a Bluetooth problem should effect all of your inputs. I ask because I am having a similar problem, but across all sources and all Dolby modes.
Old 04-25-2012, 08:44 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
same issue with FM but not really noticeable with CD
Old 04-25-2012, 02:26 PM
jwbeard's Avatar
Works with all sources - I can hear the difference very clearly between full rear, partial rear, and no rear. It just feels related to the FM signal strength, although I have no way of proving it, and I believe I should be hearing static with signal loss, not a volume reduction or loss in the rear speakers. I'd heard the aerial-equipped Vantages had horrible radio reception anyways.
As to the Bluetooth issue, I had read about some issues with the 2007 Bluetooth wiring harness. It can corrode and cause the front speakers (since they're the only ones wired to BT) to drop out.
I guess my question should be: is anyone experiencing consistently good rear speaker volume/quality on FM radio with Dolby enabled on a 2006/7 V8V? More feedback is always welcome!
Old 04-25-2012, 02:37 PM
brumma's Avatar
Is it confirmed that only the fronts are wired through? I would swear that ALL music audio cuts out when I get a phone call, which leads me to believe that the rears are wired in as well.
Old 04-25-2012, 07:06 PM
jwbeard's Avatar
All the speakers do cut out for phone calls, but that's a function of the amp. The audio leads from the BT box only go to the front left and front right, and when the harness/wires corrode, they interfere with the speakers themselves, messing up any kind of audio coming out of them.
Old 04-26-2012, 06:18 AM
brumma's Avatar
Well that's disheartening... I just ordered and paid for a new Bluetooth module in hopes that it would be the remedy.
Old 04-26-2012, 02:38 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I have a 2007 as well. The FM does cut out periodically from the rear speakers when Dolby is selected. If I take it off of Pro logic then everything is fine. I figure it is either a weak signal or the Pro Logic software. My CD and Bluetooth work fine.
Old 04-26-2012, 04:01 PM
karlfranz's Avatar
People still listen to AM and FM radios?
Old 04-26-2012, 11:36 PM
jwbeard's Avatar
Seems to be a case of "They all do that, sir!"
I'll just put FM on 3-channel and hook the Dension up to CD. Thanks for the feedback!
Old 04-27-2012, 11:35 AM
XJRS Owner's Avatar
Ok, here's what manual says for the Premium 700W system....
"Dolby Surround Pro Logic II
Not available in Radio mode"
Old 04-27-2012, 01:05 PM
jwbeard's Avatar
Interesting that the manual says that, but it's definitely in both the FM and CD menus, and improves the sound stage in FM mode when it's got a good signal.
Good to know that my radio/amp's not broken, though.
Old 04-27-2012, 02:22 PM
XJRS Owner's Avatar
Well, it's not in my menu for radio sources. Are you sure? Sometimes we misremember...
Old 04-28-2012, 05:34 PM
jwbeard's Avatar
It's not under AM, but definitely present for FM. I confirmed this morning that 3-channel isn't subject to the same issue.
Quick Reply: V8V Premium Audio, rear speakers cut out on FM?
