TPMS options for DB9?
Old May 29, 2012 | 01:34 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Originally Posted by irish07
When your swapping sensors to another set of wheels, like Aston.ca mentioned, don't mix up the sensors, keep note to it's location on the car(colored rings help)...otherwise your tpms will be detecting the wrong position untill programmed by your dealer.
When you take the sensors off your wheels, just break the outside bead, push the bead down and remove the sensor, this way when you want to swap the sensor back to those wheels, just push the bead back down and refit the sensor..saves the cost on balancing and saves the chance of scratching a mag for you never have to remove the tire..of course though you still need a tire machine to do this, but at least this way even WalMart can do this without screwing up!
Thanks C, that was my recollection from our prior convos. Good tip on swapping the sensors only, concerns about the time and balancing etc were what kept from from installing my new wheels last week.
Originally Posted by Racer_X
So does this mean that later units have removable batteries that can be replaced?
No I believe the recent units have a rechargeable system that works with motion of the wheels. It was the old Smart Tire system that had the finite life battery. Unfortunately Smart Tire is now defunct, limiting the non-OEM options. Dunno if any other vendor has reverse engineered the system. Aston must be getting their replacements from somewhere.
Old May 29, 2012 | 02:12 PM
Irish07@VelocityAP's Avatar
The replacements to Aston are still from smartire, guessing they signed a loooong contract with smartire..hense why there still being supplied to them. I know some bikes also used the smartire system, but those contracts ended and most large shops bought out the remaining stock.. they were held on like the ford tpm sensors with a band around the mag, there is actually a vanquish cruising montreal with 4 bike type sensors..hehe wonder would did that
Recent units are not rechargable, neither from Smartire or the new Beru system to Aston..all batteries will come to a end. I'm guessing when the Smartire contract ends Aston will adapt there own sensor or just make the Beru sensors work somehow..all they whould have to do is get the module to see that ID, Aston could get a land rover sensor to work, they'd have to buy the rights and fix a away to enter the ID's of that land rover (siemens) sensor
Rguy
Apr 12, 2020 11:11 PM
manfred@loma_wheels
Sep 2, 2015 11:45 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
