Possible issue with radio display?
Old Nov 30, 2012 | 07:11 PM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
I noticed something on my drive home tonight... There appear to be vertical lines that bleed from the letters on the radio display screen. They run the entire height of the screen. They are fainter than the text itself, but they are definitely there and I can see them scroll across the screen when the text scrolls. Has anyone else noticed this? Is something wrong with the display?
Here's a photo...
http://www.flickr.com/photos/brummabear/8233006941/http://www.flickr.com/photos/brummabear/8233006941/ by http://www.flickr.com/people/brummabear/, on Flickr
Old Dec 1, 2012 | 02:12 AM
uxchamp's Avatar
uxchamp is infamous around these parts
98F...Ugh...
-5C here.
I've never seen that issue, but I had the radio display go wonky with crazy characters all over once on me during hot months. heat thing?
Old Dec 1, 2012 | 08:29 AM
MichaelD's Avatar
MichaelD is infamous around these parts
Try turning the brightness down, that might fix it
Old Dec 1, 2012 | 08:37 AM
brumma's Avatar
I tried that but it didn't help. Also, I hadn't adjusted the brightness since new and it just started doing this. The text looks a bit blown out in the photo, but that is just because I shot it close up in the dark with my phone.
Old Dec 1, 2012 | 08:45 AM
brumma's Avatar
Originally Posted by uxchamp
98F...Ugh...
-5C here.
It was really only about 75ş F here. She had been parked in the garage for about an hour so hadn't had a chance to cool off or get any air moving over the temp sensor.
Old Dec 2, 2012 | 11:10 PM
sunir's Avatar
Is that the Linn audi or alpine or B&O? I've not noticed these lines on my display in my DB9 but I haven't looked super closely either .... Maybe have a tech take a look at it?
Old Dec 3, 2012 | 05:07 PM
MikeD's Avatar
MikeD is infamous around these parts
I have the same lines on mine (B&O). I adjusted the brightness down 1/3 and they became much fainter.
Old Dec 3, 2012 | 07:44 PM
brumma's Avatar
It's the Alpine, although I believe the B&O should use the same display. It would be pretty obvious at night if yours did the same thing.
If I adjust the brightness down then I can't see the rest of my instruments well enough for my liking. Seeing as it's a new car still under warranty there's no reason not to have them take a look at it. In fact, I'm taking her in tomorrow. I'll update with results.
Old Dec 3, 2012 | 07:50 PM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
LCD panel needs replacing
Old Dec 4, 2012 | 11:37 AM
brumma's Avatar
That's what I thought too. I took it in today and they're submitting it for warranty replacement. Hopefully it'll go through without issue.
Old Dec 4, 2012 | 11:53 AM
sunir's Avatar
^^^ Brumma please keep us posted on your ongoing situation. If any members can learn from this, it will be beneficial to the forum as a whole
Old Dec 5, 2012 | 11:09 AM
brumma's Avatar
Will do.
Old Jan 23, 2013 | 07:14 AM
brumma's Avatar
Just a quick update... Dropped off the car and got it back with a new radio display. AM replaced it under warranty without putting up a fuss. Just had to wait a while for approval and the part to come in. The actual install was done in a day.
Old Dec 10, 2018 | 05:22 PM
Liilpa09's Avatar
5 Year Member
Liilpa09 is infamous around these parts
I know this is an old thread but couldn’t find much on this issue....my DBS is showing the “vertical lines” as well. Just recently started happening. I’m assuming the screen needs replacing but wanted to make sure there wasn’t any other fixes. Picture for reference below.
Old Feb 10, 2025 | 02:12 PM
rhern213's Avatar
rhern213 has a spectacular aura aboutrhern213 has a spectacular aura about
Hey All, wanted to revive this thread. I'm having the exact same vertical lines issue as shown above and wanted to see if someone may have found a repair? Or if in this situation there's no solution other than replacing the display?
I've been researching and have seen the other common problem related to the delaminating polarizing film, but these vertical lines seem to be different, perhaps pixel bleeding? I assume a delaminating film would be messy, not perfectly straight lines along the text like this example.
If no other solution I might just try removing the film anyway just in the off chance it is related.
I have everything taken apart because I'm doing some other interior repairs and wanted to try and tackle this all at once.
The other option would be to try and find a replacement display screen by itself, and based on pictures it seems like the cluster display and radio display are the exact same? It would just be a matter of trying to find a third party screen from somewhere like mouser.
Appreciate any thoughts!
