Caster, camber, and toe after lowering
Old 12-20-2012, 12:47 AM
Allen121's Avatar
Allen121 is on a distinguished road
I just had BRracing install a set of H&R springs and wanted to make sure the alignment is right. I'm a little concerned about the front caster and camber. But I'm curious to know whether this is within spec.
Caster
  • Front Left: 5.0
  • Front Right: 5.8
Camber
  • Front Left: -1.1
  • Front Right: -1.1
  • Rear Left: -1.8
  • Rear Right: -1.7
Toe
  • Front Left: -0.06
  • Front Right: -0.06
  • Rear Left: 0.2
  • Rear Right: 0.2
Old 12-20-2012, 05:36 AM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
I don't know the specs for the Vantage, but as a rule any time you change springs heights on any car your alignments will change and require a trip to the alignment rack.
Old 12-20-2012, 12:38 PM
Allen121's Avatar
I had BRracing perform the alignment, but I still wanted to check to see if the specs were good. Thanks!
Old 12-20-2012, 01:23 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Way to aggressive on the front IMHO
http://www.pistonheads.com/gassing/t...Before%2FAfter
proTUNING Freaks
09-15-2015 07:28 AM
flewis763
09-09-2015 11:11 PM
Quick Reply: Caster, camber, and toe after lowering
