DB9-front wheel alignment or all wheel alignment?
Old Dec 29, 2012 | 03:58 PM
Jaime Huerta's Avatar
Jaime Huerta is infamous around these parts
I've never had to align any of my cars but the DB9 is experiencing bad tire wear on the outside drivers side tire. It was like this when I purchased it used. I ordered new tires already but want to make sure it doesn't happen again.
One shop told me front end alignment only, another states that all four wheels.
Any advice or experience with this subject would be appreciated.
Thanks,
J
Old Dec 29, 2012 | 04:16 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I would do a 4 wheel alignment. Its better to check to make sure than rear is within spec than just being hopeful that it is. Also on most cars aligning the front can throw the rear out of spec and vise versa. In other words the savings is not worth it! Get a 4 wheel alignment by a reputable shop that has a good alignment machine (Hunter).
Dan
Old Dec 29, 2012 | 05:16 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Yep full 4 wheel laser alignment as per the work shop manual (weight in seats and half tank of fuel)
The VH platform was designed to have all round adjustment of the suspension geometry for optimum handling
I know from my Vantage it makes a difference
Old Dec 29, 2012 | 05:44 PM
Thanks for the quick reply!
Old Dec 30, 2012 | 07:50 AM
sunir's Avatar
4 wheel alignment... Everytime. Especially after any suspension changes. Outer front tire wear can be a sign of toe-in up front.
Old Dec 30, 2012 | 01:52 PM
Thanks Sunir, good info.
Old Dec 30, 2012 | 02:46 PM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
4 wheel alignment always.
Old Dec 30, 2012 | 08:14 PM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
ff.
Old Jan 12, 2013 | 06:24 PM
Gentlemen thank you once again for your help. The 4 wheel alignment worked out great. All four wheels needed to be adjusted.
cnebrask
Oct 3, 2024 08:19 PM
MrMiggy
Aug 21, 2015 06:55 PM
ModBargains
Aug 20, 2015 12:28 PM
