Db9 engine knock at low rams
Old Jan 12, 2013 | 06:32 PM
Jaime Huerta's Avatar
Jaime Huerta is infamous around these parts
Gentlemen, I am feeling a mild knocking while the car is at a stop light. It feels like its not idling correctly but I don't see the rpm gauge move at all. No engine codes come on to indicate a problem. The car drives great and no idle/knock while driving, only when stopped at a traffic light. Have any of you had this problem or have any recommendations on how to solve the problem?
Thanks in advance.
J
Old Jan 12, 2013 | 07:15 PM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
Do you know if it gets louder under load? For example if you have the handbrake on and try to gently pull away in first gear does the noise get heavier and a little louder? If so, that would probably point to something serious in the engine.........
That said, this is based on my experience with other engines. I've never really heard of such issues with the venerable DB9 V12.
FF
Old Jan 12, 2013 | 07:31 PM
I have not tried that Frank, but wouldn't I notice some kind of problem while I'm accelerating hard? I've run the vehicle hard and fast in both manual and auto mode and it has no hesitation. I'll try your recommendation and let you know what happens. Thanks
Old Jan 12, 2013 | 07:58 PM
FatFrank's Avatar
Yeah, your probably right. I just thought it worth eliminating. Try it and let us know how you get on. In the meantime I'm sure some one who knows a lot more about these things than me will probably post a prognosis that is a lot more likely!
Something I tried once was taking a quick video and posting it on YouTube with a link here.....I got a lot of helpful diagnosis after that !
FF
Old Jan 12, 2013 | 09:04 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
You've confirmed the oil level is normal, right????
Old Jan 13, 2013 | 10:12 AM
sunir's Avatar
Id say check oil level and make sure the dipstick has been updated. I think on later years they changed the dipstick length but not sure exactly when or if there was a service bulletin issued I'm thinking most likely there was.
Old Jan 13, 2013 | 10:15 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
I had a ticking/squeaking sound at Idle in my V8Vantage--I would not call it a "knock". It was a Belt and Pulley problem that was corrected by changing them both.
Old Jan 13, 2013 | 10:33 AM
62Jeff's Avatar
I know nothing about the detailed mechanics of the V12, but based on my experiences with other cars, I'm thinking low oil pressure/low oil level at idle.
Old Jan 13, 2013 | 11:09 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
If you want to seriously scare yourself, have a look at this: http://www.astonmartinlife.com/forum...ise-t1162.html
Starts off about DB7 V12s but gets into later ones too.
Old Jan 13, 2013 | 12:34 PM
I will recheck the oil level to see if that's the problem. I hadn't heard about a retrofit for the dip stick so I'll have to look into that as well. If it doesn't stop I'll shoot a video so you can listen to it. One final observation, it appears that it's coming from somewhere right behind where the radio, ac et.. controls are located. When I open the hood I don't hear anything.
Old Jan 13, 2013 | 01:27 PM
yvr's Avatar
yvr
It's not unusual to get rattles from the satnav unit. Check there too.
Old Jan 14, 2013 | 07:31 AM
Checked the oil level and it was right at the max level. When I get a chance I'll drive it around and see if I can get a video of the problem.
Old Jan 16, 2013 | 01:47 PM
Irish07@VelocityAP's Avatar
Hehe..not uncommon when a DB9 runs low on oil and starts taking corners. The engine requires 12L of oil. 6L stay in the sump for reserve and 6L flow through the system. I have seen some numerous clients bring there cars to corner shops and they don't fill up the oil to the level marks..I guess they didn't realize how much the cost of oil is..anyways they fill to around 9L..with services on Aston once every 12month, some clients try to reach the mileage count instead cause thats what the corner garage told them..nonetheless car engine runs low on oil and come in on a flat bed..I am averaging 1 engine per year to be replaced from another garages mistake..Becareful ladies and gents!!!
If you can get a recording of the noise and also describe what your doing to create the noise, describe what you do to delete the noise (raise RPM past 3K, get load on engine, get engine warm...etc)..that would be great!
I have seen damaged crank bearings, rod bearings,rods, wrist pins, lash adjusters...all were not normal wear though..cosworth did a pretty good job on making bullet block..concerned engines I seen either engine ran low on oil or hydro-locked from water..all client provoked(lack of servicing, running in deep water..etc)
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Jan 16, 2013 | 03:53 PM
Thanks Irish, the weather's been a little nasty down here (we actually got to the low 40's overnight) so as soon as it improves I'll drive it around and gather the data you suggested. Great idea!
Thanks,
J
Old Jan 17, 2013 | 05:57 AM
Thanks,
J
"Nasty weather"..hehe, there calling for -15C(+5F) here by mid afternoon ..wanna trade?
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
