Fit other wheels on V8V ?
Old Feb 23, 2013 | 05:03 PM
caunyd's Avatar
caunyd is infamous around these parts
Is there any way I can fit another wheel from, say like a Porsche, onto an Aston? Is there some kind of wheel pattern adapter?
Old Feb 25, 2013 | 08:35 AM
Irish07@VelocityAP's Avatar
Yes, you can be hub adapter plates made, they might even already be avail for the conversion you want.. but on a V8V, the pattern is not rare..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Feb 25, 2013 | 09:12 AM
DoubleLow7's Avatar
DoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of light
Correct, the bolt pattern on the Aston is 5x114.3 which is common on a lot of Japanese wheels. However if you want to use wheels from a Porsche you will need a 5x130 to 5x114.3. Keep in mind you'll need to compensate the thickness of the adapter with the offset and width of the wheel to ensure you're not sticking out too much.
Old Feb 25, 2013 | 03:27 PM
caunyd's Avatar
So does that mean that any Wheel that has a bolt pattern of 5x114.3 will fit a vantage (provided I get the right spacers?).
As an example, can I use these?
http://www.ebay.com/itm/19-Staggered...7042fd&vxp=mtr
Front wheel specs:
19 X 8.5
5x114.3 pattern
Offset: +35 (Stock OEM offset is 46mm, therefore I would need an 11mm spacer to make it work?)
Rear wheels specs
19 X 9.5
5x114.3 pattern
Offset: +35 (Stock offset is 59mm, therefore I would need a 24mm spacer?)
Old Feb 25, 2013 | 03:49 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Offset sort of works backward to the way you think it should. You won't need spacers with those offsets, but the rears might extend out too much.
Here's an offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Feb 25, 2013 | 04:11 PM
DoubleLow7's Avatar
+1, see my post #2 in this thread: https://www.6speedonline.com/forums/...ml#post3734112
Aug 21, 2015 09:56 AM
pwdrhound
Aug 20, 2015 05:54 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
