Help for my V12V
Old Feb 23, 2013 | 09:29 PM
groutguy's Avatar
groutguy has a spectacular aura aboutgroutguy has a spectacular aura aboutgroutguy has a spectacular aura about
Thumbs up Help for my V12V
Hello Guys!
I noticed today that one of my air intake tube clamps was popped apart.
I have tried everything to try and compress it to get the clamp clipped back together, but have had no luck.
I also tried clipping the clamp together while the tube was unattached, and then attemted to force it on, but this was a no go as well.
Is there a special tool or tachnique to get this clamp re-attached?
Any help would be appreciated.
Old Feb 23, 2013 | 09:55 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Just make sure the clamp is lined up in the groove with the tube, there are placement marks.
Old Feb 23, 2013 | 09:58 PM
groutguy's Avatar
The clamp is lined up with the groove, but the issue is getting the clamp compressed so it will clip together.
Old Feb 23, 2013 | 10:00 PM
AMFixer's Avatar
I just use a pair of pliers to refit them, never really had any issue before. Is the metal tab on the clamp still in the slot of the clamp?
Old Feb 23, 2013 | 10:45 PM
groutguy's Avatar
Hi AMFixer!
I checked the metal tab, and it was still properly in place. I think that this particular clamp was manufactured just slightly tighter than the proper specification (probably why it was popped off in the first place).
I ended up grinding down a set of hog ring pliers to the same width as the clamp, and it worked like a charm. The hog ring pliers helped to grip under the curve of the clip edges and pop the top clip over the mating edge.
I really appreciate all of your helpful replies.
At least now I have a custom tool for future ease!
Cheers!
Old Feb 23, 2013 | 10:47 PM
AMFixer's Avatar
Glad u got.
V565MAN
Oct 2, 2015 05:48 AM
oo7
Sep 10, 2015 08:08 AM
jpetro1010
Sep 7, 2015 01:20 PM
WG_moots
Sep 4, 2015 07:10 PM
AM v12v
Sep 4, 2015 02:52 AM
