question for anybody that has the RSC green air filters in their car
Old Mar 16, 2013 | 06:41 PM
shadowhusky's Avatar
shadowhusky is infamous around these parts
I got my RSC green air filters yesterday and I was in the process of installing them but it seems strange that they are not tight around the opening like the stock ones were. it is not even snug. they will just fall off if I dont hold them up with my hand. Should I be concerned about this or will the lower portion of the airbox hold them snug against the upper portion of the airbox.
Old Mar 17, 2013 | 07:05 AM
jmargolese's Avatar
jmargolese is infamous around these partsjmargolese is infamous around these parts
I have had mine for over a year, no issues. I even had the dealer remove them and clean them during my annual with no issues. I would assume they would have mentioned an improper fit if it was an issue. But, I have never touched them myself...
Old Mar 17, 2013 | 11:07 AM
gircal's Avatar
gircal is infamous around these parts
Yes, I have been told that once placed in position, the lower portion of the airbox will hold them properly against the upper portion. This is normal.
Old Mar 17, 2013 | 01:15 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
it' s ok, no problem
Old Mar 17, 2013 | 02:12 PM
Thanks everybody. With as difficult as it is to get to them, I didnt want to put them in and then realize that maybe I could have possible received the wrong filters.
Old Mar 17, 2013 | 03:14 PM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
Once installed, you'll notice a very subtle improvement in your cars performance too.
Old Mar 19, 2013 | 12:37 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Yes this is how they 'fit'. Others have put a thin foam spacer underneath to elevate them to the right height. When I put mine in, just for convenience bc it is a bit of a pain, even with the car on a hoist, to get them to stay in place as you put the box back together around them, I put a dab of a mild adhesive around the outer ring of the filter that inserts into the flange inside the box. This held them in place long enough to get the box back together.
Old Mar 19, 2013 | 01:40 PM
macksamus's Avatar
macksamus is infamous around these parts
Makes me uneasy...is there a reason RSC that these filters aren't manufactured to fit like the OEM filters?
Old Apr 1, 2013 | 07:29 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
any chance of some pic of this ? Im hoping to replace my stock filters soon with the new washable ones from AM bits UK, and am not sure waht to expect when I remove the front under tray? I dont have a lift so it will be tricky as it is with simple jacks
Old Apr 1, 2013 | 10:37 AM
[QUOTE=captain Greg;3808923]any chance of some pic of this ? Im hoping to replace my stock filters soon with the new washable ones from AM bits UK, and am not sure waht to expect when I remove the front under tray?
it is pretty simple once the car is up.
I ended up taking the front wheels off to remove a few of the bolts in the wheel well of the wheel well liner so I could get at the airbox screws easier. you have to flew the wheels well liner out of the way because it extends under the front of the car.
Old Apr 3, 2013 | 09:54 AM
vince_1972's Avatar
Old Apr 3, 2013 | 03:09 PM
Aston.Ca's Avatar
Don't need to remove the wheels. Use bungies to pull the liners back once teh wheel well screws are removed. Irish posted a great step by step in an older thread if you search.
Old Apr 3, 2013 | 03:19 PM
please snd me the link I cant find it? I really enjoy Irish posts he knows his stuff!!!
Old Apr 10, 2013 | 01:20 AM
riverflyer's Avatar
riverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud of
Or even better, post the link if you could. I have a pair in the box still, awaiting installation. thanks, John
Old Apr 10, 2013 | 11:55 AM
Aston.Ca's Avatar
