Black grill,window trim and mesh ?
Old Apr 3, 2013 | 12:55 AM
DoubleLow7's Avatar
DoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of lightDoubleLow7 is a glorious beacon of light
Boaz, I'm sure you've seen my car a million times but I have the blacked out window trim. I'll be doing the hood and side vent meshes next, but probably not the front grill...
Old Apr 3, 2013 | 08:48 AM
Breezman's Avatar
Breezman is infamous around these partsBreezman is infamous around these parts
It looks great on your car, was curious about a black one. Just ordered the side and hood mesh in black and getting a black grill from another member. i can always switch back.
Not sure what to do with the window trim yet???
Just like the one in the link i posted few posts ago
Old Apr 3, 2013 | 05:34 PM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
Originally Posted by Breezman
I meant the window Trim-lol
Doh! Yep, looks good. Just like mine
Old Apr 3, 2013 | 07:39 PM
Breezman's Avatar
How did u do it?
Old Apr 3, 2013 | 08:56 PM
FatFrank's Avatar
How did u do it?
With a very thin vinyl wrap. One large piece that covered the whole side daylight opening, and installed in situ without having to remove the bright work. I did at first think that I would have to remove the bright work in order to wrap all the B-surface return flanges, but the guy that did it said that to remove them was not necessary and he was right. When he applied the heat gun the wrap contracted tightly around the bright work, and with a little help from a thin spatula, he easily tucked it under the seals to create a close to factory appearance IMO.
Looks great, and I can revert back should either I or a future owner decide to switch back to the bright. I did originally look at having the brightwork painted at the same time as my rear bumper was off for painting, but the paint shop recommended against it and that I wrap instead given other cars that they had seen.
FF
Old Apr 3, 2013 | 09:05 PM
Breezman's Avatar
FF
cool, sound like a good reversible option.
Old Apr 4, 2013 | 07:21 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Easily reversible if you don't like the effect.
Most big-box home improvement stores stock the spray cans.
Old Apr 9, 2013 | 10:18 AM
Breezman's Avatar
Thanks to Mario, there is the Black grill..!!!
Old Apr 9, 2013 | 05:25 PM
DoctorWill's Avatar
DoctorWill is infamous around these parts
Wow, that looks like a fun little project!
PlastiDip on Window Trim - Black Out Chrome Window Trim on Your Car - Dipyourcar.com - YouTube
Old Apr 9, 2013 | 05:47 PM
DoctorWill's Avatar
I wonder if the material can withstand the heat from the engine or exhaust. It might make a mess if the melting point is too low.
Old Apr 9, 2013 | 09:02 PM
marioV8V's Avatar
marioV8V is infamous around these parts
Looks great Breez! Glad I could help out. I'm enjoying the bright finnish grille I got from you, thanks again!!
Lowtush
Jan 25, 2022 10:48 AM
Apex Chase
Mar 28, 2016 02:00 PM
Sep 1, 2015 03:16 PM
