AOS Catch Can
Old 07-12-2013, 03:15 PM
karlfranz's Avatar
How many nibbles have you got on your project so far?
  #32
Old 07-12-2013, 03:51 PM
telum01's Avatar
four, myself included.
  #33
Old 07-12-2013, 03:55 PM
TurboDragon's Avatar
TurboDragon will become famous soon enoughTurboDragon will become famous soon enough
Forgot to ask is all the oil coming form the vent lines to the crank case?
Is so DANG.
  #34
Old 07-12-2013, 05:09 PM
telum01's Avatar
Is so DANG.
This comes directly from the PCV:
  #35
Old 07-16-2013, 08:05 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
Great work telom01, please put me down for one.
It sound like the mounting will be a clamp style to go around the catch can.
  #36
Old 07-17-2013, 10:31 AM
telum01's Avatar
Will do, and I'll PM you payment info.
It's actually going to be a pair of bolts that fasten the can to the mounting bracket. The t-shaped mounting tab on the can prevents a clamp from wrapping around properly. The bracket will have nuts welded on where the bolts go when you mount the can, which will make it easy to remove, and without the hassle of dropping loose nuts.
  #37
Old 07-17-2013, 10:44 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Just now digging into this thread and contemplating adding this to my V12V. Do you know if your system will work for the V12?
  #38
Old 07-23-2013, 12:25 PM
telum01's Avatar
My kit won't fit on a V12 because the engine, intake duct, and throttle body are all in the way:
Old 07-23-2013, 01:19 PM
Racer_X's Avatar
^^^Okay, so when will your V12V version be ready?
  #40
Old 07-23-2013, 01:29 PM
telum01's Avatar
LOL! Well if I can get my hands on a V12, I'll be happy to look into it!
  #41
Old 07-23-2013, 02:20 PM
Irish07@VelocityAP's Avatar
Fittings would be different..But you could use the catch can minus the brackets and mount them yourself in place..btw you would need 2 catch cans for a V12, there are 2 PCV's that feed to each air intake tube
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
  #42
Old 07-23-2013, 03:25 PM
telum01's Avatar
as soon as i saw Racer_X's post, i pulled up the diagram to see where the system was since it couldn't have the same layout as a V8. looks like the PCVs are under the intake manifold, is that right? if so, it'd be a lot more work than my setup for the V8!
  #43
Old 07-23-2013, 03:43 PM
There are 2 oil air separators in the engine valley area(below intake and fuel rails), both are on there own circuits, they goto there own pcv at back of the head, then a vent from the cam cover goes to this hose, hose then feeds to the intake tube few inches in front of the throttle body..left and right side systems are a mirror image
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
  #44
Old 07-24-2013, 08:29 PM
telum01's Avatar
The group buy organizer is trying to get the wrinkle black available as an option (no cost difference). If this gets approved, I need to know which finish you want! If I don't hear from anyone, I'll have to default to the brushed finish.
I'll be PMing people as well so hopefully everyone will get a chance to respond.
  #45
Old 07-26-2013, 07:30 AM
telum01's Avatar
UPDATE: The group buy organizer was able to get the black finish included in the group buy. I've already heard from a couple people about their choice. Unless I hear otherwise, I'll be defaulting to the brushed finish.
FOR THOSE WHO HAVE NOT YET PAID, I NEED PAYMENT BY THE END OF TODAY!
Quick Reply: AOS Catch Can
