Vantage lowering springs
Old Jul 19, 2013 | 07:11 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
My Porsche is even lower than the AM, but that means nothing...they both scrape!
Don't lower if you are too worried about scraping. I would change your swaybars to something thicker. I wonder if the swaybars on the GT4 would fit an older Vantage.
The front looks to be able to take a "speedway" style swaybar and you could always opt for adjustable arms to dial in your handling. Price will be in the $700+ range, but I know where you drive and it will be money well spent.
Old Jul 19, 2013 | 09:18 PM
riverflyer's Avatar
riverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud of
Originally Posted by DoubleLow7
The skidplate is attached via the mounting holes on the CF front splitter and via 3M doublesided tape. As for the tire sizes:
20"x9" 255/30 Fronts , 20"x11" 305/25 Rears
That is the sizes I was going to run but MichSS dont come in the front configuration and I really prefer those tires. What kind are you running?
Old Jul 20, 2013 | 05:52 AM
stevewushu's Avatar
stevewushu is infamous around these parts
Originally Posted by drcollie
I have a brand new set of H&R Springs in the box for my 2007 Vantage (3/4" drop) and I don't think I'm going to drop the car after-all - so I'll sell them for $ 400 + shipping if anyone wants them - never even out of the box.
We have so many driveway transition aprons here in Virginia that I think I best stay stock height.
Hi Duane
Just sent you a visitor message about your springs...
Old Jul 20, 2013 | 11:21 PM
riverflyer's Avatar
Tell me more, not sure what a speedway style swaybar is. This is for '11 V8VS.
Old Jul 21, 2013 | 12:11 AM
marioV8V's Avatar
marioV8V is infamous around these parts
@DoubleLow7 can you post pics of your skid plate, I'm in the process of installing V12 bumpers along with carbon fiber splitter and rear defuser. I was worried about scraping the front splitter, but it sounds like you have a great solution to that problem
Old Jul 22, 2013 | 11:08 PM
AMv8's Avatar
AMv8 is infamous around these parts
I have a 07 vantage and found the suspension a bit too soft. How much do the springs (the less aggressive set) improve handling? Very noticeable or marginal?
And how much does it affect the ride. I don't want the ride to be rock hard.
Thx
Old Jul 26, 2013 | 01:21 AM
riverflyer's Avatar
Thanks. They look awesome.
I have ordered a set of ADV 1 wheels in track spec. 20x9 and 20x11. I got 245/35 and 285/30 for two reasons, more sidewall and to get the ferrari spec MSS tires in Ferrari spec, due to the almost 15lb weight savings.
Old Jul 26, 2013 | 09:48 PM
Just Google "speedway swaybar" and you will see what I mean. There is some home work involved. You will need to figure out how thick of a bar to get (the straight bar going across), and then the length and style of the arms.
You could even get a ****pit adjustable arm, but then you will need to get through your firewall to mount the adjuster, etc.
If you really get interested in this project I might just do it with you as well.
Old Jul 29, 2013 | 05:15 AM
stevewushu's Avatar
What's the comfort like with HnR springs?
Old Jul 14, 2014 | 02:28 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
bump for any more info on ~1" drop on springs
Old Jul 14, 2014 | 02:34 PM
telum01's Avatar
I'm fine with the comfort level but that's a very subjective topic.
It takes some effort to pay attention around potholes and speed bumps, but I've gotten used to cringing so usually it isn't an issue.
On decently smooth roads, the ride is fantastic. One rough roads, it's fine but you'll notice the bumps. I don't mind it and wouldn't go back to stock.
Old Jul 14, 2014 | 04:32 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Mikey, there is a set of springs enroute from my manufacturer to my tester right now. We are aiming for a 0.5-0.75" drop, and using a proprietary process which allows a true progressive rate spring.
Could be good on the A & B roads, and not TOO aggressive on the lowering.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Jul 14, 2014 | 05:49 PM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
I have H&R springs and love the ride - but it is a pain dealing with it ... If I didn't live in "flat" Florida - I would think twice about em ...
Old Jul 14, 2014 | 06:34 PM
karlfranz's Avatar
Does the bottom of your splitter have any scrape marks on it already?
Old Jul 14, 2014 | 10:54 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I may actually plan on getting Stuarts "True Progressive" springs from Velocity as the H&Rs are just too much of a drop (my subjective option). Also roads in Texas can be terrible even in the best of places, and my driveway entrance is steep.
If Stuart is willing to sell me just the rears I will definitely like to lower the rears as it sits higher than the fronts. I do not want to risk scraping the front chin by lowering it in Houston, it's already "close".
By squatting the rear it will lower the back end and improve the handling of the car in transitions as I always felt the rear of the car always lagged in rebound speed compared to the fronts (which I never really had any problems with.). The V8 Vantage does have a heavier rear weight bias so most of the dynamic improvements need to happen at the rear of the car. I notified a significant improvement in the rear shock rebound rate when I upgraded to 2-piece brake rotors last time as it shaved 18lbs total and really helped the rear end stay much more planted as if it has an additional aero spoiler. Such is the benefit of massive weight reduction on rotating mass.
The remainder of the improvement will be achieved when I switch to the 2-piece brake rotors from Velocity both front and rear as the stock rotors are just way too heavy (which is partly why our Vantages have such a notoriously rough ride when it comes for he first inch of initial suspension travel. Paradoxically after that first inch it gets way too soft. I am glad Stu is taking the initiative to do this new generation of springs because it's honestly something we have needed for quite some time as a community.
So how bought them rear springs Stu?
P.s. I would like to know the stock spring rates front /rear and how the range of the true progressive rate springs to get an idea how soft it is initially and how sporty it gets at the limit.
Rockinc1
Sep 30, 2015 06:44 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
