10k mile report
Old Jul 20, 2013 | 09:14 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
10k mile report
Just completed my first 10k miles in my 07 v8v. Car is equipped with every option and has power upgrade and high flow cats. First and foremost, the car, though used as a dd, continues to make every little journey an occasion. I am more impressed with design and build quality with the passage of time and accumulation of miles.
Observations :
1. Gas quality dramatically impacts performance and gas mileage.
2. Not tightening the fuel cap properly will cause an emission system service fault that must be cleared.
3. Michelin PSS are the tires for this car (IMO)
4. You will never tire of hearing the engine over 5krpm.
Old Jul 20, 2013 | 10:13 AM
plastique999's Avatar
plastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to all
Curious what Emission code did you get?
Old Jul 20, 2013 | 11:41 AM
oo7's Avatar
oo7
Emission system requires service,
Old Jul 20, 2013 | 03:08 PM
Yes common problem....but did you use an OBD scanner to read the code prior to erasing it? was it P2195?
Old Jul 20, 2013 | 04:33 PM
oo7's Avatar
oo7
Yes, I think that was it "small leak" BTW I have 16 more points that did not go into the original post I will try to renter this evening
Old Jul 23, 2013 | 10:05 AM
telum01's Avatar
Observations :
This is all true at 38k miles, too
Old Sep 17, 2013 | 01:12 AM
Christiaan0922's Avatar
Christiaan0922 is infamous around these parts
Observations :
007, congratulations on successfully reaching the 10K mark. I just got there recently myself with my 2007 DB9. Other than the factory installed sport pack my DB9 is all stock. I'm very curious to know what you discovered in regards to "gas quality" impacting performance and gas mileage. I haven't noticed any difference myself, but am wondering if that's because my car lacks the modifications you have installed. Could you elaborate a bit on that?
Thanks in advance.
Old Sep 17, 2013 | 03:05 AM
oo7's Avatar
oo7
I have the prodrive performance upgrade and it is fuel dependent. What I think occurs is the timing is advanced as far as possible until a knock sensor registers a complaint.
Old Sep 17, 2013 | 07:44 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
@Christiaan0922 -- Your V12 is old school like mine. Nothing is variable, so it can't take advantage of higher grade fuel, and there are no knock sensors so it can't adjust for poor quality gas either.
I always fill mine with the best at the pump on the premise that (a) I want to avoid any knocking and (b) higher quality gas should have more & better additives.
Old Sep 28, 2013 | 09:17 PM
Hi YVR, thank you for the info, much appreciated!
audipwr1
Sep 25, 2021 01:31 PM
turkish1
Nov 11, 2015 09:01 PM
gulf gt
Aug 27, 2015 10:27 AM
