Rotor Question
Old Sep 30, 2013 | 09:11 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
The 370 rotors would technically work! You would just have uneven pad wear and have to massage the opening on the rotor to fit the hub a little. 3rd Gen Vipers have a very similar spec layout, 355mm X 59mm(7mm too deep) but unfortunately, they are a 6 lug design. Lots of "close" relatives but none close enough to deem useable in my opinion.....
Old Oct 2, 2013 | 08:53 AM
rb4u's Avatar
rb4u is infamous around these parts
Originally Posted by ArtB
Well guys, I have a bit of bad news..... I got a used 370Z rotor in Friday and after measuring and fitting, the Z rotor is 2mm too shallow for our hub! The hub opening is only 66.1mm and the Aston hub bore is 68.08. That's an easy fix with a lathe.....But the hat offset is 2mm too shallow, so the brake caliper won't line up exactly evenly with the pads. There is no left or right adjustment whatsoever with the radial mounted calipers, so it's a no go on the 370Z rotor. SO CLOSE!!! I have contacted Stuart at Velocity for a set of 2 piece rotors all around and just be done with it. I will post pictures of the install. Hopefully they will arrive this week along with my new 20" wheels. Pics to follow!
Artie
370Z hub opening, according to my research, is 68.1mm. Where you get 66.1mm?
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
hacellular
Aug 31, 2015 08:34 AM
awchristler
Bentley
Aug 24, 2015 03:53 PM
TrackOne
Aug 20, 2015 12:56 PM
