Interior Driver side Door handle Woes...
Old Oct 20, 2013 | 03:20 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
started to touch on it here, but obviously a lot going on in that thread..
https://www.6speedonline.com/forums/...om-quirks.html
i went to tighten the nuts on my arm rest (removing the aluminum door grab) i removed it very cautiously.. but 5th time opening door after which it did not want to open..
i removed it again, seeing that whenyou pull it... the plastic "fixed" piece slides off the metal "L" bracket...
after bending the L slightly over 90, it did it once more so i wedged a piece of wood in there to prevent it from coming off..
now it does not want to open the door again but exterior latch works fine.
i feel that it's the side inside the door binding up. (as it takes increased pressure to pull)
anyone have the write up to inspect that piece.. or any idea of cost?.. when i removed the door skin the cable went to behind the metal.. i see the exterior door latch and it works fine.. i assume the part that controls the driver door is the problem
anyone ever have this problem before? i find it important to exit my vehicle!
Jul 29, 2019 11:13 AM
tkeck3
Aug 25, 2015 02:52 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
TrackOne
Aug 20, 2015 12:56 PM
