Cable routing from engine bay to cabin
Old Oct 28, 2013 | 10:54 AM
pacastro's Avatar
pacastro is infamous around these parts
Hi everyone,
I'm installing some laser jammers in front of my V12V and I'm trying to figure out how to route the cables from the front engine bay into the cabin, any grommets on the firewall I can use or any other way to get cables into the cabin?? everything is really crowded there and can't find anything I can use...
Any help will be really appreciated.
Regards,
Pablo
Old Oct 28, 2013 | 12:37 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Not sure about Aston Martin, but I'm sure you could try this trick...works in most other cars...
Remove any trim panels just above the pedal cluster on the driver's side. Climb down there and look just above your pedals on the firewall. 9 times out of 10 you'll see a pretty easily accessible grommet just above the pedals. Carefully poke a small screwdriver or pick through it...and leave it there. Then go into the engine compartment and look for it with a flashlight. My guess is you'll find it pretty easily somewhere just below the firewall bulkhead. Hope that helps...
Old Oct 30, 2013 | 07:01 AM
pacastro's Avatar
Good idea Tom,
Will look down there to see if I can find a grommet I can use.
Thanks for the help!
Pablo
Old Dec 12, 2013 | 10:49 AM
pacastro's Avatar
Thanks a lot Tom,
Found a grommet above the clutch pedal, I used it to get throught the firewall with the cables I needed. Its a very tight space on the engine side, but taking your time you can do it safely without damaging anything.
Thanks again!
Pablo
Jul 29, 2019 11:13 AM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
ECS Tuning - VW
Aug 26, 2015 02:54 PM
Ferrari
Aug 24, 2015 04:35 PM
Glasig
Aug 23, 2015 03:35 PM
