Rear Boot (Trunk) button does not work
Old Nov 5, 2013 | 07:10 AM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
For some time the operation of the trunk release (external) button was intermittently not working, now it does not work at all. The switch inside the car works as does the remote FOB.
I am assuming it is the switch, but of course it could be in the wiring. Has anyone experienced this. I was considering just ordering the switch before pulling the car apart, how hard is it to remove? I did not see in the shop manual.
Old Nov 5, 2013 | 12:02 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
It would not be the wiring, as if it were your fob and inside power release would not work. That leaves only the external switch itself. Intermittent followed by failure is a sign of dirty contacts, what you can do before ordering a switch is get some spray electrical cleaner and get that into the switch itself. Might fix it and its certainly cheap to experiment with.
Old Jan 21, 2014 | 02:59 PM
millsjq's Avatar
I case anyone experiences this issue, I replaced the trunk button/switch ($125) and it solved all my issues. Replacing the part was very easy other than removing the four plastic trim plugs (mushroom push in trim plugs) on the boot liner. Irish, is there a special tool or technique to remove these?
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
r_matt_6
Oct 8, 2015 06:07 PM
no1joey
Sep 2, 2015 12:32 AM
gulf gt
Aug 27, 2015 10:27 AM
