ahhhh!! emmission service light came on!!!!
Old Dec 9, 2013 | 11:46 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
Originally Posted by karlfranz
Timing the release of the buttons after the three flashes is critical. The first time I did it I was successful in about 3 tries. But the next time took me about 30 tries. If you don't hear a faint chime (similar to when you leave your lights on) then it didn't work.
Ill try that..... thanks... sounds like i was just doing it a little wrong.
Old Dec 9, 2013 | 11:58 AM
XWCGT's Avatar
Well, you helped me do it in one time, after your guidance! Thanks. worked like a charm, right down to the little chime.
no more service required warning.
thanks again!
Old Dec 10, 2013 | 04:26 PM
jmargolese's Avatar
jmargolese is infamous around these partsjmargolese is infamous around these parts
Originally Posted by jmargolese
I just had mine go off as well after a hard day at the track on my last lap. Car was due for annual and inspection so it's at the dealer. Will update with what the issue is and repair.
Just heard from my dealer, the heat shield was not seats properly around my after market cats and headers, thus causing the o2 sensor to burn out and a few fuses to short. Hopefully, that's it, still waiting for more details.
Old Apr 23, 2014 | 05:12 PM
RicoDB9's Avatar
RicoDB9 is infamous around these parts
I have an 07 DB9 Sport with 27k on it. I have the typical AM battery issues. In fact it just happened to me last week. Battery went dead and "Emission Service" light went on. It has done it before.
IGNORE IT. Make sure your gas cap seal is clean and cap is tight. Drive it for a few hundred miles and it will go out on its own.
WORSE CASE is go into AM and have them reset the code. If it immediately comes back on you may have an issue but I'll bet you 3 beers it doesn't.
With respect to battery tenders, you can buy a fully electronic 2A smart charger for $40 at Canadian Tire... if your patient they go on sale every once in a while for $25. It has a cigarette lighter adapter and I plug it right into the cigarette lighter interface thing in the trunk... works like a jet!!!
http://www.canadiantire.ca/en/pdp/mo...l#.U1hBFF6_fVk
Old Apr 23, 2014 | 06:23 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
Can someone clarify. Doesn't the emission warranty run for 8 or 10 years on all cars sold in the USA?
Old May 28, 2017 | 07:32 PM
XWCGT's Avatar
It just came on again!
I just put Shell gas in.. never did that before, (I don't know, superstition) and only put in 5 gallons.... the emissions light /warning went on. got home and did the service request warning removal process. right up to the little chime... but nothing changed..... maybe just drive it, fill the gas tank up and make sure the gas cap is on tight??
thanks
Mark
Old Jun 12, 2017 | 01:48 PM
Denver V8V's Avatar
Denver V8V is infamous around these parts
Is the procedure of holding the T1/T2 button with the Read button etc... for all Vantage models and years? I have an '09 with the emissions warning light on and I've tried various other procedures mentioned in another thread in this forum, with no success so far. It's not the gas cap, I checked it for tightness and also recently filled the tank to see if that would make a difference.
Old Jun 12, 2017 | 01:50 PM
Denver V8V's Avatar
I checked with the local dealer and Federal Emissions warranty does run for 8 years or 80,000 miles from the date the car is put into service
Old Jun 12, 2017 | 09:07 PM
XWCGT's Avatar
i put some more gas in. light still on. cant find the error message with my obdII reader, only an old one for a low engine temp warming from a year ago. BUT, when i finally filled the tank all the way...............the warning light went out! so, is that the answer. the vantage doesnt like partial fills at the gas station?
Old Jun 13, 2017 | 06:50 AM
Denver V8V's Avatar
I wish that woud've worked for me, I filled the tank and even washed the car and the light is still on.
Old Jun 13, 2017 | 07:23 AM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Wow washing the car didn't fix it! LOL. Do like my friend Norm and just put a piece of tape over the light.
Old Jun 13, 2017 | 09:47 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
I can't believe washing the car did nothing!
Old Jun 13, 2017 | 05:58 PM
Denver V8V's Avatar
Remember what the old timers would say when a car stalled and couldn't get it started?
Hit it with a hammer!
Amazingly it would often work. I was trying a more modern, caring way of accomplishing the same
Old Jun 13, 2017 | 07:19 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
On the bright side...washing your car will help you forget the light as now water in your headlights and taillights...kidding...smile rough group on this site.
Actually like the tape idea...lol
Old Jun 15, 2017 | 09:23 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
My 07 DB9 has the emissions light come on every time I drive in rain for long periods and it never has a code or at least a code my reader picks up.
