10k service??
10k service??
Did anyone here did the 10k/one year service and can shed some light on what is needed/required by Aston?
Have 2 local dealers with two different answers…..
Thanks,
B
Thanks,
B
They are actually saying that different things needed to get done
This was 1s dealer-
Annual Service $755.00 (Oil & filter change, brake, tire, multi point vehicle inspections & comprehensive road tests).
Tire Balancing $100.00
Fluid Flush $345.00 (recommended Bi-annually)
Cabin Pollen filters $345.00
2nd dealer-
Engine lube oil & filter change, top off fluids, set tire psi to spec,
Perform fuel injection cleaning, replace remote batteries, perform visual & safety inspection and battery test.
The cost of the Service is $1130.00+Tax
2nd dealer-
I need to open up my own AM repair shop. The annual I do myself and its less than $100 in parts.
Your owners manual will have what is required every year. Most of that stuff you can do yourself. I would probably go with the first dealer as you seem to get more for your money. They include the brake fluid flush as required in their annual service for $755.
What fluid are they changing that requires a bi-annual change (it wasn't mentioned)? Per my owners manual brake and oil are done every year and coolant every 5 years. AM has the trans and diff fluid as filled for life but I would recommend changing it every 10 years or 30k miles which ever is first.
My 2005 owners manual says to change the brake fluid annually. However, I do agree this is excessive for a street car. You are fine changing the brake fluid every 2 years IMO.
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
