leak at oil filter.....
Old Dec 29, 2013 | 04:33 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
Question leak at oil filter.....
noticed a small spot on garage, jacked up car and noticed the drips coming from the oil filter (the other day on highway the car in front of me had some sticks/etc falling out back and i remember hearing one hit under the car)... the oil filter has a ding and a flat spot on it where it's having a slow drip.
i know that normally removing the oil filter means a full oil change, but curious on the dry sump setup if i could just remove the filter and top it up or it's just like every other car?....
only reason i ask is the last time i had the oil changed the dealer slightly overfilled it and it was a real pain in the butt, so not sure if i trust em..
if i took it somewhere, what is the proper amount of oil to be used so I can not have the overfill issue again.
thank you.
Old Dec 29, 2013 | 05:12 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
You can remove the oil filter on most any car and truck and not lose more than 1/2 a quart of oil in most cases. No need to change the oil in the sump. Stick a new one on, run the car and check the oil, the fill as needed.
Old Dec 29, 2013 | 05:33 PM
wa1l1in's Avatar
thank you... that makes life much easier...
i'll take it to my local guy tomorrow then, ive been checking the level and it's a slow leak but also a very easy fix..
again, thank you.
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
Lucid Moment
Sep 12, 2015 01:12 PM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
ricks234
Sep 10, 2015 12:51 PM
