Tire inflator kit
Old May 20, 2014 | 07:46 AM
karlfranz's Avatar
There is an outlet on the back of the car beside the fuse box.
Old Mar 2, 2015 | 11:47 PM
dsvantage's Avatar
dsvantage is infamous around these parts
Hi folks,
Do you have any other sources for the tire inflation kit for a 2009 Vantage? The eBay link a few posts ago says the seller is away. Thanks!
Old Mar 3, 2015 | 06:58 AM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
Originally Posted by dsvantage
Hi folks,
Direct from Continental
http://www.tirerack.com/accessories/...Tire+Inflation
Old Mar 3, 2015 | 07:59 AM
Irish07@VelocityAP's Avatar
There's always a Land Rover dealer, not sure on the price but should be cheaper than AM.. There used on the new Sports and Full-size with a 7 seater
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Mar 3, 2015 | 09:53 AM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
Here's a link to the small one. Ended up not getting it since I don't know how to strap it to the fuse box :X
http://www.ebay.com/itm/CONTINENTAL-...3D261584094422
Old Mar 3, 2015 | 10:15 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Slime?
Any reason not to carry a bottle of Slime and any small generic compressor? (Other than aesthetics, of course...)
Old Mar 3, 2015 | 11:21 AM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
I've had to replace tires with slime in them and what a mess. I've always repaired my own with a kit from Safe T Seal. Higher quality tools and plugs than you find in the local parts store though not cheap.
As far as compressors go I'd look for original type or look into the ones motorcyclists use. The have some good quality but compact solutions. You get what you pay for applies here also.
Old Mar 3, 2015 | 02:33 PM
zuman's Avatar
I understand what you're saying, Dave, but is that any different than the factory solution?
Old Mar 4, 2015 | 08:39 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Caution: If you buy one from e-bay seller, be sure of the expiration date. One being offered expires in Dec. 2015.
Old Mar 4, 2015 | 06:40 PM
karlfranz's Avatar
Yes, it is different. The factory Continental kit forms a liner inside the tire that can be peeled off like a sheet of rubber.
Old Mar 4, 2015 | 07:20 PM
karlfranz's Avatar
BTW: If you want an even better solution for permanently repairing holes in tires, look into Dynaplug.
Old Mar 4, 2015 | 11:42 PM
dsvantage's Avatar
Originally Posted by 62Jeff
Thanks for the link, I ordered one but there's a one month wait. At least the expiration date should be further out than the eBay version.
Do you know if these come with the mounting hardware for the coupe, or should that already be installed against the wall of the car? The entire kit was missing when I bought my car.
Old Mar 5, 2015 | 04:19 PM
62Jeff's Avatar
This is just the pump and tire goo container assembly. I bought one for my 07 vette, was identical to the one in my 09 DB9.
Old Jun 1, 2024 | 06:00 AM
sweet991S's Avatar
5 Year Member
sweet991S
So, my question is: Why can't I just use this??
Old Jun 2, 2024 | 10:04 AM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
Perhaps you would be better starting a new thread than adding to one that's 9 years old because info has changed since then.
To answer the question, the problem with those filler cans is that you have likely ruined the tire. In a case where you just need some air to get you to someplace which can repair the tire, you want to use the air pump.alone. I also really worrying about having something left in the car that contains something under high pressure. Add some heat and you might end up sealing your trunk.
