AMV8 clutch observation
Old 03-26-2014, 04:01 AM
oo7's Avatar
oo7
oo7 is offline
oo7 will become famous soon enoughoo7 will become famous soon enough
Originally Posted by XWCGT
keep in mind, when you let the clutch out, the torque tube spins. its no different then the front engine front transmission cars. the ONLY diff, is that the transmission is in the rear, and the shaft that comes out of the flywheel is a lot longer . releasing the clutch suddenly, in neutral, spins up the drive line, as it does in any car. putting the clutch to to floor, and the driveline stops (when the car is standing still)
TOB is always spinning , as it is being held in position by a clutch lever arm. different forces exist on the TOB (throwout bearing) when you pus the clutch in. now, the bearing has a lot of axial force on it. but its still spinning , just the same.
Just to be clear, you are certain the TOB is spinning continously, engaged or not?
Old 03-26-2014, 09:53 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
yep, kind of a misconception. its always spinning, but when engaged via a arm or hydraulic set up, there is then an axial load on it, but its always spinning.
Old 03-28-2014, 06:23 PM
oo7's Avatar
oo7
oo7 is offline
Ok, I may be confused here and need some help. I 'm a little thick. The TOB is always moving yes, however, when not working it spins with shaft it resides on, or eventually does unless it is dragging, so though it is moving the bearing is not really moving much at all and of course no load. So the only time it is really spinning ( at a different speed than the shaft) is when engaged and a little after disengagement. Am I getting this right or has something changed I am not aware of? I know Irish informed me of a differing design in actuation. I would be amazed if an unlubricated bearing could last so long, but then again my phone scrolls through text using my eye movement.
Old 04-19-2014, 11:27 AM
oo7's Avatar
oo7
oo7 is offline
So happy my post was not responded to as it caused some fact finding. Indeed the throw out bearing is always moving (provided car is not in n) just as we on earth are always moving even if we are standing still. "Spinning" may be a bit confusing to us simple folk. Turning with the shaft is more accurate and easier to understand. Hopping on the 9n to plow the back 40 now.
Old 04-19-2014, 12:08 PM
XWCGT's Avatar
Actually, its not like us sitting on the earth and the earth is spinning. its really spinning and getting wear with every revolution of the engine flywheel. (i.e. when the engine is running )
the reason is that the TOB is tied (fixed) to the flywheel.. the flywheel spins, the TOB inner part that is attached to the pressure plate, which is tied to the flywheel , spins. the outer portion is fixed to the bell housing and doesnt move. (it has the lever arm , that also is attached to the bell housing and activated by the slave cylinder or has a network of hydraulic hoses attached to it, but either way, it doesnt move)...........so, there is a bearing that separates them that is always being used and is wearing. there is MORE wear when you engage the clutch, because of the axial load on the sleeve that is tied to the pressure plate to engage the clutch. regardless of it being in neutral.. (shaft spinnning), in gear, (shaft spinning), or with the clutch in. (shaft not spinning in neutral, and spinning at the speed of the appropriate gear , if in gear).
So, you see the TOB is always spinning and being worrn. the shaft inside of the TOB is floating through the inner diameter and not generally wearing or touching anything on its outer diameter.
Old 04-19-2014, 05:30 PM
oo7's Avatar
oo7
oo7 is offline
I am confused. How does the throwout bearing touch the flywheel?
Old 04-19-2014, 05:47 PM
oo7's Avatar
oo7
oo7 is offline
I get it now. Pics in manual helped. Thank you for your patience.
Old 04-19-2014, 06:53 PM
XWCGT's Avatar
Its not touching the flywheel, but spinning with the flywheel, because the pressure plate is bolted to the flywheel. the "spinning " part of the TOB is fixed to the fingers of the pressure plate, so its always spinning if the engine is running. (regardless of the shaft running through it is at the same rotational speed or stopped.
I think you get it now. its not that obvious, and so many people think that the TOB is only worn when the clutch is pressed in, but actually, its always spinning, but the axial load changes when the TOB pulls the fingers back off the pressure plate to release contact on the flywheel. noise can occur when you press the pedal in , if there is a bearing problem, as the problem will make more noise when the bearing is loaded. the other noise that you can hear if you let the clutch out in neutral, is the torque tube shaft spinning..... it has bearings located in the torque tube that can go bad.
ECS Tuning - BMW
09-16-2015 07:20 AM
Blue Chip
09-10-2015 07:07 AM
ECS Tuning - VW
09-09-2015 03:11 PM
ECS Tuning - VW
09-09-2015 12:01 PM
ECS Tuning - VW
09-03-2015 09:43 AM
Quick Reply: AMV8 clutch observation
