- The Official Stock Wheel & Tire Weight Thread -
Old Apr 15, 2014 | 08:10 AM
telum01's Avatar
I've topped out 4th gear a time or two lol...
While many people might not notice a few pounds here and there, some of us do continue to modify our cars over time. So while one change might not make a big difference, over time the cumulative modifications will add up to an overall better performing car. A pound here, a few there, it adds up.
Holds true with dropping weight with a lighter hood, trunk, exhaust, seats, wheels, brake rotors, pulling out floor mats, the trunk divider, etc... There's no one magic answer, but there are a lot of small steps to get closer. Of course, everything comes with a trade-off.
Old Apr 15, 2014 | 10:04 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
Originally Posted by 007 Vantage
Acceleration in gears 1st - 3rd are by far the most important are they not?? . Lol.
I don't know how many people go WOT in 4th on the street, you are well into triple digits at that point. Yes obviously as gears get higher the effect is less, but for around the street it makes the most difference as the first 3 gears are the ones most of us have the most fun in which is why IMO they are the most important ones to focus on.
Vergis, XW is actually right that rubber does in fact weight more than aluminum based on volume, with that said its important not to neglect the wheel weight as well. They are ALL important. By carefully planning your modding plan you can find an all encompassing solution like I did trying to save as much weight as humanly possible with every component you replace. Remember, I removed 8 pounds while massively increasing the widths of my wheel & tire combo without event touching the brakes yet. A full 2-piece Brembo brake kit will save roughly another 36lbs!! However, that weight reduction does come at a smaller radius so it's impact is slightly less, but the mass reduction is far greater so it will still make a noticeable improvement in handling, braking, steering response and feedback. Bumps will be much softer still allowing you to then compensate by going with a more aggressive spring setup with no negative ride quality compared to stock.
My main purpose of this thread was to illustrate the point how important it is to plan ahead when doing mods and not just doing it haphazardly (which most tend to do). Depending on how long I keep the car I will probably end up doing rotors as well for a maximum effect.
Wi regards to rotating mass, the same is true for crank pulleys and lightweight flywheels, they always have the greatest impact in 1st - 3rd gears (the most relevant for city driving). But I am getting ahead of myself ... In due time.
Ok, I'll comment on this one........well, "most important"? Actually, the greater rotating drive line weight effect will have most effects in 1st -3rd gear, IF (again) its on the flywheel , but if its on the wheels and tires, its going to be even though all gears vs another car without the extra rotating weight. (this is because the gear ratios of the transmission REDUCE Proportionately, the reflected inertia to the engine when the weight is added or removed from the wheels and tires)
Yes, getting that weight out of that rotor is a big deal , because if its 8lbs per rotor, even if its only 1.2x or 1.3x that of which could be inthe car, thats still 10lbs per corner, and 40lbs over all. 40lbs in most cases is like picking up a free 4hp, and that 4hp is available from start to finish of any drag race!
Old Apr 15, 2014 | 10:31 AM
XWCGT's Avatar
Originally Posted by MichaelD
Just to throw in another thought.
How many of us have filled the tank and noticed the car feeling sluggish straight after? Yet that is maybe 60 pounds of additional weight added in 5 minutes. It was when I realised that my personal butt dyno didn't notice a 60 pound difference, that I stopped thinking about spending a few thousand on weight saving changes.
On the track its all measurable, but on the road what really matters is how much extra pleasure you get out of any changes you make to the car, and apart from the satisfaction of knowing you've made a difference, I'm not convinced that the car will feel any different with the weight reductions being discussed here.
EXACTLY! Yes, and let me tell you... I cant tell you all the qualifying set ups , racing that only put in just enough gas to qualify in a race with a 450hp/3000lb race car, saving the racing fuel load of the extra 5 gallons of gas (30lbs) and actually ran faster on my first few laps with the extra weight! its SO minimal the effect, you really cant feel it, because there are so many other factors. (competitive mist, tires, track temp, air temp, and small set up changes) that can over shadow 40 to 60lbs of extra weight. however , LARGE changes, like a passenger will add a couple of seconds to a lap time. (ive done this back to back experiement with a passeger seat in my race car with a body in it )
ive also done tests with students as far as removing weight or adding weight and asked them what felt different. sometimes with the spare removed or something, they said the car felt heavier. trust me, its way to minor to tell, if you are running with 60lbs or not.
now, unsprung weight is different, as long as we agree that the weight on the tires is worth 1.4 as it was in the car only as far as acceleration goes. it will make the sterring feel more crisp and on tight tracks, the suspension will work better. we are talking tracks here though. im still amazed if anyone can push their car hard enough on the street to reallly feel the difference . I would bet a HUGE dinner that i could mix and match heavy vs light wheels and tires and no one could feel the difference in a double blind test on the street.
Old Apr 15, 2014 | 10:40 AM
XWCGT's Avatar
With body weight you are 100% correct, that's why I don't waste a dime on body weight reduction, it honestly does next to nothing. Rotating Unsprung mass though is a completely different world compared to body mass. Apples vs. oranges. Once you try it you will be hooked. Wheels/tires/brake rotors are the first things I usually modify on cars now to maximize performance because they literally affect everything (handling, ride quality, grip, steering response, acceleration, braking, on and on).
I agree, but as far as the weight's effect on acceleration and braking, its really only 1.4x that of the weight in the car... hey, still a bargain right! and braking, not so much..... in fact, the extra weight on the tire, probably is better because of its resistance to lock up. that 4 or so hp for 30 lbs savings on all 4 corners is paltry compared to the 1000 or so HP available from the braking system. remember, the entire weight of the car and the wheels and tires are tied together as one inertial mass reflected to the brake rotors. Grip? debatable other than the tire can keep contact better with a lighter rotating mass over bumpy surfaces. ride quality?? that's personal preference too. heavy stuff tends to feel more solid, but its not as responsive, as you mention . Handling? yes, but only so far as the road's characteristics. lots of tight turns and bumpy? yes. lighter is much better. a track like laguna seca? not so much. very small movements for the tires, and pavement is smooth. Sebring?? yes, absolutely!
Old Apr 18, 2014 | 03:48 PM
AJN334's Avatar
AJN334 is infamous around these parts
There have been many different wheel options within the Vantage line, it would be very interesting to know if there is any substantial weight differences between the options.
I am thinking the 20 spoke 'mesh' design must be a boat anchor...
Old Apr 18, 2014 | 05:31 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
For street use, weight loss in the tires/wheels is a very expensive and barely noticeable proposition. What is it worth to you?
Old Apr 18, 2014 | 10:27 PM
XWCGT's Avatar
Absolutely! what kills the truth here, are the constant testimonials of the anecdotal evidence and mis calculations of math/physics that show that there are gains to be had. unfortunately, there is little or nothing that can be felt on a street car, let a lone a race car by saving 5 lbs a corner on wheels and tires.
Old Mar 20, 2018 | 07:22 AM
Maximilian's Avatar
Maximilian is infamous around these parts
Very interesting discussion. I just wanted to pick-up the topic of the thread and ask you: are Semi Slicks such as the Michelin Sport Cup 2 heavier than normal Michelin/Pirelli tires (Michelin Super Sport or PZero). And if choosing the Sport Cup 2 for our Aston, how much difference is there still to the standard Bridgestone.
The reason why I am asking is that i need a new pair of tires for my V8 Vantage S and I am thinking to change to sportier and lighter tires. The car is only used on sunny weather conditions and regularly on track days during the year.
Best regards,
Maximilian
Old Mar 20, 2018 | 02:09 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
I've had PS Cup2's on my V12VS for several years now. I'd never go back to the OEM PZero Corsas. Like you, I generally drive mine in dry conditions and occasionally on track. I think the Cup2's as a street legal tire are the best of both worlds in this scenario.
Last year I was caught on the road in some heavy rain and thunderstorm conditions with not much tread remaining, but I was surprised at how drivable the Cup2's were in those conditions - I had no problem at the speed limit.
Old Mar 22, 2018 | 06:09 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Great info! Tires are often the most overlooked, but their weight is crucial
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
RS GT3 RS
Sep 24, 2015 09:27 PM
WheelB
American Muscle
Aug 24, 2015 08:42 AM
Aug 19, 2015 06:35 PM
