New Wheels Fitted
Old May 2, 2014 | 08:23 AM
XJRS Owner's Avatar
New Wheels Fitted
Bought some wheels at a good price. How does the fitment look to you guys? Too much outward projection or just right?
Last photo: custom polished center cap machined from billet with badge inset.
ID:	369494   Click image for larger version
ID:	369495   Click image for larger version
ID:	369496   Click image for larger version
Old May 2, 2014 | 09:55 AM
rscultho's Avatar
rscultho is infamous around these parts
Looks nice - colors are complimentary. That's a DBS isn't it? Or a newer DB9?
HRE wheels? From one angle the rear looks like it may be out enough to contact the fender on extended wheel travel, but from the angle looking back from the passenger door it looks ok. Don't want to roll your quarter panel!
Do you have any spacers on or is this just the wheel offset?
Old May 2, 2014 | 09:59 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
I think they look good. Nice job.
Old May 2, 2014 | 10:10 AM
XJRS Owner's Avatar
No spacers, just the wheel offset as manufactured. Well, not quite....
Rears were 36 mm, so had a friend machine off 3 mm, resulting in a 39 mm offset vs stock 54 mm. So wheel is pushed outward 15 mm as compared to OEM. Also, taller rear tires (285 x 35) for a little more ground clearance and a better ride (+22 mm dia increase). Plus they do a better job 'filling the gap' in the rear arch.
Fronts are only +2 mm outwards (40 mm vs OEM 42 mm offset). Tires are also taller in front, but only by 6 mm dia resulting from going to a 255 vs stock 245 (same profile).
If I was getting new wheels, I'd use a 44 mm rear offset and leave the fronts at stock 42 mm. This way the rears would only be out by 10 mm vs the 15 mm I now have. After summer, I may have a couple more mm machined off. Probably can't do more than 3 mm extra without having the lug nuts penetrating the mounting face of the wheel, at which point you'd be screwed since the nuts would bottom on the rotor hat before the wheel did.
So, will drive around and see how much I like them the way they are.
Old May 2, 2014 | 10:40 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
what width rims?
Old May 2, 2014 | 11:07 AM
XJRS Owner's Avatar
Originally Posted by XWCGT
what width rims?
stock width: F 8.5/R 11.0
Old May 2, 2014 | 11:12 AM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
Very Nice
Old May 2, 2014 | 11:18 AM
karlfranz's Avatar
Good job. The wheel centers look like a quality job. Are you happy with how they came out?
Old May 2, 2014 | 11:30 AM
XJRS Owner's Avatar
Yup. Mr friend machined them out of aerospace grade alloy on a 5-axis Haas CNC, I then polished them up with a dremel and stuck the badges on in the machined recess. A truly quality job.
Old May 2, 2014 | 03:55 PM
XWCGT's Avatar
255 on a 8.5, like the vantage? it comes stock with a 235 and folks are going up to 235. i thought the 255 would look a lot better. the rear being a 275 is tiny too, and thought a 305 or 295 would be better the rear vantage rims are 9.5".
Old May 2, 2014 | 05:19 PM
XJRS Owner's Avatar
Not quite sure what you are trying to say here; a little confusing.
Old May 2, 2014 | 05:55 PM
XWCGT's Avatar
im asking, do the 255s fit on the 8.5 " rims??
are you sure they are 8.5" on the front like the vantage?
are the rears really 11s? if so, why not go 305s
vantages are 9.5 on the rear. they push the 275s to 285. if you have an 11s, that 285 should look a little undersized.
Old May 2, 2014 | 07:46 PM
XJRS Owner's Avatar
Quite sure about widths.
8.5 is the min approved width for a 255, and 11 the max for a 285, so no problems with fitment. No 305 because I don't want the tire sticking out farther than necessary, and the 285, being a 35 profile, keeps it from looking undersized. And keep in mind that those humongous 305s add quite a bit of extra weight for little added benefit.
I think people have a tendency to go wider just for the sake of saying they've got these huge tires (just like HP).
Old May 2, 2014 | 08:24 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Looks great! As you say, helps to reduce the unsightly "gap" Aston seems to favour.
Then again, I am just a little bit biased, with the same wheels...
Old May 2, 2014 | 08:33 PM
XWCGT's Avatar
interesting that the DB9 had the 11s in the rear. just a FYI, 305 is the ideal size for an 11, and ive actually raced it up to 335s which is a tight fit, 12s are better. 315s are perfect for the 11s. interesting that the 255s work on the 8.5. ill probably do that with the stock rims next time. I dont want to go too much taller, so might go 255x30, as that might be as tall as the 235x35 on there now..... rears , same thing , might go 295x30 if they make it or do the 285x35 and just make it a little taller.
actually the larger tires do work better, as does more power, but on the street, its more important to look better as we all know.
