Gear box erroneous, function rescued error message
Old May 5, 2014 | 09:13 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
On my 2009 DB9 I have noticed that when I start the car and hit D button, some times there is a very brief message in display which says something like
"Gearbox error, function reduced" this message goes away in 1-2swcond. Car seems to be driving ok but hey I am new to this car.
There is no check engine light or any other persistent error message.
Is there a problem? Should I get it checked out?
Old May 5, 2014 | 09:31 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
I've seen that on my 09 DB9 when I don't press the gear selector button with any conviction. Once I began pressing the buttons more deliberately instead of quickly, I've stopped seeing the error.
Old May 6, 2014 | 05:17 AM
Hi 62jeff,
Can you clarify what you said above? Is there specific way you are pressing drive button now vs before?
Thx
Old May 6, 2014 | 06:15 AM
62Jeff's Avatar
Originally Posted by Wildcat1212
Hi 62jeff,
Thx
Sure. The few times I got the error it was when I pressed and released the "D" button very quickly, as if I was in a hurry to get going (which I was!). I'd say I was more or less tapping it instead of pushing it.
Now when I press "D" I press and hold it down for I guess a half second or so and I've not seen the error since I started doing that. I have NO idea if there's any correlation or if it's just coincidence but it's free to try. The error hasn't happened to me in at least a year since I changed my "D" behavior.
Old May 7, 2014 | 07:23 PM
WildBob's Avatar
WildBob has a spectacular aura aboutWildBob has a spectacular aura about
This is a common error on AMs with autos, but it is nothing to be concerned about. It will store a code when it happens, but just have the dealer clear it out on your next visit...I cleared mine last week during an event at a dealer...no charge!
Old May 7, 2014 | 08:52 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There is an update to the switches and sbw module. Also have seen many cars with dirty grounds for the buttons. This causes a high resistance in the circuit and if the sbw module doesn't see the voltage it wants the warning message appears.
The Oss
Aug 24, 2015 08:19 PM
