Engine start button
Old May 19, 2014 | 02:17 PM
jroback's Avatar
jroback is infamous around these parts
Engine start button
I am having occasional problems with the engine start button.
The first problem occurs after I have inserted and turned the key and then waited a few seconds. I depress the brake and clutch, but the red light surrounding the button does not come on. If I release the clutch and depress again, it usually does light up, but sometimes I have to do it 3 times.
The other variation on this problem is that the light comes on, I push the button, the car starts to turn over and then dies. I release the clutch and then depress it again, the button turns red, I hit it again and the car starts.
These problems are intermittent, but I'm wondering if they suggest a significant problem? Any thoughts?
Old May 19, 2014 | 02:22 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
low voltage on the battery perhaps? Perhaps a battery on it's way out?
Old May 19, 2014 | 03:31 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
I had a similar problem and then realized the wires coming from the switch on the clutch pedal (safety switch?) were loose and not making good consistent contact.. Stick your head up under the dash and it's pretty easy to get a look at.. Made some new connections and solved.. Good luck.
Old May 20, 2014 | 08:54 AM
jroback's Avatar
Thanks for the suggestions. I'll let you know what I find. JR
Old Sep 25, 2015 | 02:17 PM
airbusdrvr's Avatar
airbusdrvr is infamous around these parts
Start button
Hi
Did you ever find what the starter button problem was?
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
